wire colors
Old Sep 18, 2015
metalpres's Avatar
metalpres is an unknown quantity at this point
wire colors
Quick question, on a 2014 Civic ex without nav, does anyone know the color of the 12v switched wire in the radio wire harness? Trying to do an amp install and dont want to have to check every wire individually if someone already knows which one it is.
Old Sep 18, 2015
Re: wire colors
Accy+ = Purple in connector A #24, but test it to make sure before you do anything to it.
Old Sep 18, 2015
drhawkinz's Avatar
drhawkinz has a spectacular aura aboutdrhawkinz has a spectacular aura about
Re: wire colors
are you putting in an amp with the factory radio?
Old Sep 18, 2015
metalpres's Avatar
Re: wire colors
yes that was the plan, just adding an amp for a subwoofer.
Old Sep 19, 2015
drhawkinz's Avatar
Re: wire colors
the radio have RCA preouts or are you using line-out converters?
Old Sep 20, 2015
metalpres's Avatar
Re: wire colors
using a high level to rca converter. should be able to connect right into the rear speakers.
Old Sep 23, 2015
metalpres's Avatar
Re: wire colors
thanks for the info, installation went fine, it was in fact the purple wire like you said.
CraigW
May 24, 2015 09:49 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
