DIY for headliner removal with pics??? PLEASE!!!
fuk tha man!
anybody got it or know where I can get it???
thanx
also does anybody have the DIY again WITH pics for the dash pad removal, not the whole DASH, just the the dash pad (the full front part)
thanx
First you have to remove all of the upper trim pieces that touch the headliner. Also, the dome lights, handles, Rear View and sun visors. If you have a moonroof, remove the screw in plug where you attach the manual crank.
If you have a moonroof, there should be three clips in front of the moonroof that pull straight down, Then there should be two right behind the moonroof that you release by pulling the headliner toward the back of the car.
No moonroof, I think there are two clips in the back and the rest are glue tape.
Good to have someone help you lower it since you don't want to put any creases in it.
The A pillars just pop straight out. Just pull on them sideways.
The B and C pillars are harder to get out.... You have to remove your backseat and all the lower piece trim in the rear to get these out... and when I say all the lower trim, I mean every pannel in the rear... that's including your rear deck too.
fuk tha man!
^^^^ are you one hundred precent sure, I remember somebody saying that they didnt need to remove it...they had removed the whole thing and then came to see that it wasnt necessary...I think
im 500% sure, you have to remove anything and everthing on and around the dash, including the steering wheel. Pull the dash out of the car, and access all like 20 something screws behind it.
Crack kills... But then again... So do I...
Originally Posted by soonercivic
the center part of the dash is a padded vinyl. The section that runs across with the vents, gauges, a/c, and radio in it. Its got a thin pad behind it, thats why its soft when you push on it.
Ahhhhh..... Gotcha.... Thnx....
Jul 12, 2015 11:54 AM
ballmich
Jul 9, 2015 11:59 AM
CivicsClass101
Jul 9, 2015 11:14 AM
