transmission swap scam
im stock now! T.T
Rep Power: 265 transmission swap scam
ok so my tranny was gone so I replaced with another ex tranny or so I was told. I just broke it in and got to redline it today and gears seem longer. I have an 01 honda civic ex coupe and the guy i bought the tranny from said it was from an 02 ex, the reason why the ex gear ratios are short is so that you will be in vtec, my new tranny everytime i redline, i get out of vtec, so thats how i know somethings wrong.
Or could it be that honda has changed the ratios in 01 and 02? i mean the tranny i bought works fine no problems at all, only thing is that third goes up to 90 mph before with my torn up tranny, my third only went up to 80.
this is a good thing if I was turbod so ill have longer ratios in a gear but since i am back to stock it is very very bad...... any opinions will help, thank you.
im stock now! T.T
Rep Power: 265 it works great but it is not a good combo for n/a, this ****ing pisses me off cause the guy i bought it from is a good friend of mine and now hes nowhere to be found.
im stock now! T.T
Rep Power: 265 im going to check the vin number to make sure, but for some reason i cant find the vin anymore, is it possible to check the vin from above the car or do u have lift it?
im stock now! T.T
Originally Posted by aznboysrfr
02 is the same.
you might have an lx/dx tranny. if your 4th redlines at 115-120 mph, then you have that .. if your 4th redlines at 110, it's an ex tranny.
i doubt that the tranny redlines at 110 cause earlier i was redlining 3rd and it went up to 90+ so im sure 4th will redline at 120+ dammmit!
Originally Posted by Civic_RedLine
ill try redlining 4th later, but whats the disadvantages of using a lx tranny, just that i dont go in vtec when redlining gears?
U get about 1mpg worse in the city and 1mpg better on the highway. And it wont accel as fast. That "friend" is pretty shady to b pullin that kinda **** on u. <------------ Do it. Do it
Rep Power: 0 Maybe you can swap the diff, if i'm not mistaken the dx/lx was 4.25 or 4.11 and the ex was 4.40...don't remember that well, since mine is 2001 and it's been a while since i read that. you might wanna check with other guys...maybe your old diff still good...
so watch out for ""friends""
DOHC i-VTEC TiMEX
My 3rd redlines right around 87-ish.
90+?? ... maybe you got an HX tranny
im stock now! T.T
Rep Power: 265 so whats the difference, my car wont accelerate as fast>? and why is this? so im actually losing power from this swap? also lx tarnny has longer gear ratio cuz when im cruising on 5th i still got lots more to go compared to my ex tranny which didnt let me go that high.
DOHC i-VTEC TiMEX
slightly better gas milage though
im stock now! T.T
Rep Power: 265 actually it might accelerate slower but top end should be the same, cuz the gears are longer no? i gonna check for sure which model the tranny came from.
DOHC i-VTEC TiMEX
Rep Power: 338 all the gears will accelerate slightly slower ... more so 4th and 5th. again, think of a bicycle. It takes a lot more torque to try to spin a larger gear vs. a smaller gear.
DOHC i-VTEC TiMEX
Rep Power: 338 if you ran normal boost (8-ish), I think the shorter final drive is fine ... but if you're running higher boost, longer gears would be nice since traction is your friend.
when I was running 7 psi on my turbo, I had run dead even with an e46 M3, a FEW sti's and a modded srt4, all from a roll... I'm not sure if having a longer final drive would've changed that. I never really broke my tires loose with the final drive, so I think my EX final drive worked out great
WaryDriver
23
07-22-2015 07:18 PM
07-12-2015 11:54 AM
begogadashi
06-11-2015 04:04 AM
alexkharden
04-23-2015 07:13 PM
