I'm searchin and searchin and I can't find any info on AC removal!
Touch it... He won't bite, He'll just come at you pretty quick.
Can some one help me out? or is my best bet to buy a service manual? I mean what belts will I need after the ac is removed? Also... is it a good idea to remove the PS as well at the same time? Or will I hate that?
First of all, why would you want to remove your AC?
Second what belt are you talking about?
I've remove a few times, and it is a pain in the *** to take out and put back together. If you're not careful removing it, you can crack the high pressure aluminum piping. Also ur gonna need to spend some more money buying new AC coolant afterwards.
how could you not use it. we've had over 90 degree weather for the past few months almost 1 of every 2 days!
i try that but its too hot for me. i am always driving in hazleton though so im never getting over 45. to and from work i put down the windows since its under 4 miles away but any other times im dieing!
...Ok then... Dont know why ur doing this, but i'll help you out.
There are 2 ways to do this.
1. To remove the AC, the high and low pressure pipping are on the driver side, top/bottom right corners. The bolts are screwed from behind the AC, so you'll need to remove it from the inside. (Yes, this is the pain in the *** part). You'll need pretty small hands and ratchet. If you dont care about putting it back or the well being of it, you can pull it out about an inch and it'll give you more room to work with. Unscrew the bolts until you see/hear/feel the coolant stuff leaking out. Be careful not to let the coolant hit ur face! Once all the coolant has been drained, completely remove the bolts and yank that sucka out.
2. The other way is much easier. Remove the high and low pressure pipping from the AC compressor. (Let coolant drain before removing the bolts completely.) Now the AC can be pulled out a lot further so you can remove the screws from the pipes. This way you dont have to squeez your hands between 2 inches of space to work with.
Now if you want to remove the AC unit, have the system evacuated first. Then you can start pulling off lines and components.
hehe, I didnt realize that myself. Yesterday, I started taking the lines, off, than I hear, PSSSSSSHHHHHH loud as hell. For about 4 minutes. I shoulda known better, but couldnt even get my car anywhere. no valve cover, turbos off, IM off (almost), fuel rail, everything is apart, so I had to. I wont next time, I didnt know it damaged the environment.
Peace.
Peace.
can i buy your AC supplies? depending if everything is in good condition?
i took it out of my car when i was boosted, now NA and its a bitch... i want it back NOW. i have most of the stuff already, just need a couple of things.
you'll need a DX belt its like 15 bucks...everything else is just taking apart, not too hard. it just takes time. if you can't figure it out, i can help further.
Peace.
Peace.
Touge
May 20, 2015 10:54 PM
