Sqeaky clutch? fix it then..
Old Sep 25, 2005
eziey's Avatar
eziey is an unknown quantity at this point
Arrow Sqeaky clutch? fix it then..
took me about 5 mins to stop the squeak.
ill try to get some pics on here soon.
1. go underneath your steering wheel and take off the panel that covers the
fuse box
2. there should be another panel that cover the arms that go to the pedals,
take this panel off too so you can see all the way up to where the arms
connect.
3. at the top of the clutch pedal you should a lil silver rod going through
the wall (when you push the clutch , you should see it move)
4. take some wd-40 or some of the lithium grease stuff , and put it on the
silver rod ,and push the clutch in and out some so it stops sqeaking
5. if it doesnt stop then , put a lil more on there , it will stop once there is
enough on there.
6. put the panels back on and your done.
Old Sep 25, 2005
04|5spdCivic's Avatar
Wish I had a Turbo 3)
04|5spdCivic can only hope to improve
i've done this. it actually made my squeek go away too. i did this a couple months ago.
Old Sep 25, 2005
eziey's Avatar
yeah , i did mine a long time ago , but i just saw a post on some other way to do it, so i put this way up
Old Sep 25, 2005
ncirom2003's Avatar
thank god, only 20k miles on my 02 and i hear this crap........i was goin nuts.
Old Sep 25, 2005
2k1sohc's Avatar
Member
2k1sohc is an unknown quantity at this point
That used to work for me. Now it only works for a couple of weeks, less if it rains. I am probably going to give up and just buy a new clutch master cylinder. I think there is a secret warrenty on this in the States (nothing here in Canada).
Old Sep 26, 2005
Azizst's Avatar
Azizst is an unknown quantity at this point
What does rain got to do with a sqeaky pedal problem? What's the reation?
Old Sep 26, 2005
01hx5's Avatar
01hx5 is an unknown quantity at this point
The moisture causes some oxidation, causing the squeak to come back sooner. Atleast thats the conclusion i have came to with my vic.
Old Sep 26, 2005
Azizst's Avatar
Ok thanks
Old Sep 26, 2005
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
I have tried all the lubing I can on my vic. Our little clutch squeak is very annoying. I work at a honda dealership and the only way I was able to get rid of it was to replace the master cylinder and slave clyinder. I replaced the parts with genuine honda parts so who's to say it wont come back, at least this is what I am assuming. Bad thing is honda doesn't want to replace the master or slave because they are only making noise not going out. I could only claim one part to be faulty and even that I had to lie about breaking to get the part under warranty. So basically the conclusion I have come to is; it's a civic, it's built with cheapness, and lots a plastic.
I have had the new parts on for only a day so I'll see how long the quietness last
Old Sep 26, 2005
eziey's Avatar
i have only done mine one time , and i havent had a prob with it yet , even in the rain, and trust me , i have had plenty since i have done it , i live in the panhandle of fl , right near pensacola , and i fixed it before hurricane ivan , and it hasnt squeaked again , and its been through like 4 hurricanes and a hella lot of rain
mikemc422
Aug 9, 2018 05:41 PM
begogadashi
Jun 11, 2015 04:04 AM
CaptainAmerica
Feb 3, 2002 09:36 PM
Sparty
Transmission
Jan 22, 2002 03:41 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
