Airbag question - SRS
Old Jan 21, 2002
SQCivic's Avatar
SQCivic is an unknown quantity at this point
When I removed my front seats, I had to unplug the sensors from the bottom of each seat which of course causes the SRS light to stay on. When I replace the seats with aftermarket ones like Sparco's for example, is it just a matter of attaching the sensor on the bottom of the new seats to have the airbags functional again?
Old Jan 22, 2002
Jimmy24's Avatar
Jimmy24 is an unknown quantity at this point
I don't know man but,,,,you got to be really carefull when messing with the airbag sensors.
If you take it to somebody who knows about this system or electricity, they might bypass this plug with a jumper wire. It must be real easy. How many wires does each plug has?
Old Jan 22, 2002
GTekCiViC's Avatar
GTekCiViC is an unknown quantity at this point
All you need to do is transfer the plug from the old deats to ur new sparco seats.....
than ur srs will work fine and the light will go away.....
Old Jan 22, 2002
Confinement's Avatar
Confinement is an unknown quantity at this point
i dont get it, somehow my sensor is screwed up and i tried to reset the light and it didnt work, i checked all my seats and stuff but everything looks ok i dont understand whats wrong. can someone help me?
Old Jan 22, 2002
GTekCiViC's Avatar
did u make sure all the wires were plugged in under the seats?
Old Jan 22, 2002
CaseysGuy385's Avatar
CaseysGuy385 is an unknown quantity at this point
Just so I know what I am up against... I plan to take my seats out this weekend to install dynamat on my floor. If I unplug the wires, do my dynamat thing , put the seats back in and plug the wires back in, I should be in good shape right? I don't want to have to mess with the SRS light staying on, and I sure don't want my airbags to be all screwed up! Do I have anything to worry about?
Old Jan 23, 2002
0100010's Avatar
0100010 is an unknown quantity at this point
If you unplug the seats, then the next time you turn your car on, your SRS light will be on. Probably the easiest way to not have them come on is to disconnect your battery first.
Old Jan 23, 2002
SQCivic's Avatar
OK, I didn't disconnect the battery first. Now what are my options?
Old Jan 23, 2002
GTekCiViC's Avatar
blow up ur car
or take it to the dealer........
Old Jan 23, 2002
SQCivic's Avatar
So a Honda dealer can reset the SRS no problem?
Old Jan 23, 2002
Toronto's Avatar
Toronto is an unknown quantity at this point
Reset Your SRS Light
Old Jan 23, 2002
SQCivic's Avatar
Thanks!
juror
Suspension DIY
Jul 30, 2019 03:28 AM
GotSiR
Jun 23, 2016 04:06 PM
ek_rebuild
Aug 11, 2015 08:00 AM
Kinneybrk
Jul 24, 2015 02:41 PM
jzhartman
22
Jul 23, 2015 10:42 PM
