How do you get at your gauges?
Old Jan 3, 2002
DriftR's Avatar
DriftR is an unknown quantity at this point
I see 2 screws up top of the gauge housing. Take those out and then what? Seems like the bottom is still fastened on by something. (I hate just "ripping" things out)
And what after that? HOw do you take off the clear plastic cover once the housing is off?
Old Jan 3, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
You gotta put a flathead screwdriver underneath the bottom of the trim and pry it up. just be careful not to scratch anything. after that you should see some screws and its pretty easy on what to do from there....
Old Jan 3, 2002
antidote11's Avatar
antidote11 is an unknown quantity at this point
You don't even have to use a screwdriver, just pull it out, it is connected by two clips, ut just pull hard at the bottom and it will pop off.
After that, the rest is self-explanatory.
Old Jan 3, 2002
Maximus's Avatar
Maximus is an unknown quantity at this point
Yup........just use your fingers to get in between (I started at the top of cover, where it arcs), then pull hard (after you remove the 2 screws first, of course). The first time you do any sort of mod, you probably have the tendency to be a bit ginger, but you will have to tug hard on that cover to get it out. After that, there are but 3 screws (two on the bottom left & right, one on top) to remove, and then you just unplug the 2 wire harnesses. Good luck!!!
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
raymondxcho
Sep 29, 2015 09:00 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
srtlat
Sep 17, 2015 11:02 PM
