a q about my grill
Old Jan 6, 2002
wishihadavtec's Avatar
wishihadavtec is an unknown quantity at this point
a q about my grill
ive made the grill already, but i cant figure out where to tie down the grill in the corners cause i dont want to drill unless if have to, if i do drill where would i drill to tie down the corners?
Old Jan 6, 2002
LexBoy's Avatar
LexBoy is an unknown quantity at this point
i wouldnt recommend you to ummmm.....do it yourself unless of course you are a mechanic or know how to do it
Old Jan 6, 2002
LexBoy's Avatar
its worth to pay the money
Old Jan 6, 2002
0100010's Avatar
0100010 is an unknown quantity at this point
I drilled a set of two 1/16" holes, in the black area in the corners, about 1/4 back from where the lip of the black plastic starts, behind the painted area. The to holes are about 1/8" apart from each other, so that way I could run a wire "up" one hole, over a peice of the grill, and "down" the hole right next to it, and then I twist closed the wire behind the bumper. Works perfectly, holds it securely, and you can't even see the holes unless you get your face about 3 inches from the grill.
Old Jan 6, 2002
VNlilMAN's Avatar
The Standard One
i got mine on without any drilling or cutting, all i did was use a fishing line and tied it.
Old Jan 6, 2002
MY01HX's Avatar
MY01HX is an unknown quantity at this point
Hey man get a hold of ALLMAN, at one time he was making them and selling them for ours cars.
Old Jan 6, 2002
nuffsed's Avatar
i'm in the process of doing mine.... how did u guys protect the edges from scratchin the paint?
I've been having loads of problems... but i will not pay someone $40... the most i'd pay is $10...
Old Jan 7, 2002
to protect the paint from the grill i put some 1/8" clear tube around it. its works great and looks even beter
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
rnaodm
Sep 21, 2015 12:42 PM
1.7ali
Sep 6, 2015 07:36 AM
