Turbo question: enligten me
Old Jan 6, 2002
h2k1ex's Avatar
h2k1ex is on a distinguished road
Iīve been reading about turbos and that there isnīt a system designed for the 2k1, my question is that if it was possible to install a turbo from another car into the 2k1???
Old Jan 6, 2002
Confinement's Avatar
Confinement is an unknown quantity at this point
i am sure you could all you need is the know how and the piping at least thats my opinion
Old Jan 6, 2002
LexBoy's Avatar
LexBoy is an unknown quantity at this point
if it were that easy, my friend would have done it a long time ago
for me, i need a realiable source of input before i do anything to my car.........
i dont think you cant do that i'm juss saying, it will pretty much f uck up your car
Old Jan 6, 2002
h2k1ex's Avatar
Of course I would never do this to a new car hehehe, but I was reading a magazine where they did that to a B16A, they got an t3 turbo from a mustang svo and installed it, the turbo gave about 11 psi, with other mods it gave something like 342 hp
Old Jan 6, 2002
htowncivicEX's Avatar
htowncivicEX is an unknown quantity at this point
The turbos themselves are made from independent companies (Garrett, Turbonetics, et al) and can be used in any car, it's the supporting equipment that needs to be custom-fitted to work properly.
Old Jan 6, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
<< all you need is the know how and the piping >>
exactly
Old Jan 7, 2002
pinkytoe's Avatar
pinkytoe is an unknown quantity at this point
01civicboi- um yea knowing the piping is good- its farly easy to create- the problem lies in the manifold and downpipe-
Old Jan 7, 2002
Jimmy24's Avatar
Jimmy24 is an unknown quantity at this point
You got to be really carefull if you are going to do it because, if they come out with a turbo for us, well, it is designed for our cars(psi, compression etc), but if you just take one from another car, you might brake yours. You got to be really carefull or whoever is going to do it.[IMG]i/expressions/face-icon-small-sad.gif[/IMG]
Old Jan 7, 2002
2k2civic's Avatar
All turbos are the same - a mustang turbo would work on a civic, an integra turbo would work on a mustang and so forth. The turbo itself is not the part that has to be designed for the car - the piping is. As far as boost pressure goes, the boost controller and blow-off valve will keep that to a safe level. But it's not as easy as getting a turbo and intercooler installed - you also have to upgrade your fuel delivery (definately) and igniton (maybe) systems to compensate for the increase of air in the cylinders.
Hope that helps, and if I am wrong, someone please correct me - I don't know everything about turbos but I'm trying to learn all I can.
Old Jan 7, 2002
Jimmy24's Avatar
I guess 2k2civic is right!
Old Jan 7, 2002
robbclark1's Avatar
Retired suspension supermod.
So if we were to find a wrecked car with a turbo in it, we could just pop it out and have the rest all custom??
Old Jan 7, 2002
SiSi's Avatar
SiSi is an unknown quantity at this point
There are a few shops here in toronto where they can build custom manifolds to be used with pretty much any turbo. However the one shop I talked to said that because it wouldn't have the R&D of a mass produced turbo he wouldn't recommend any crazy amounts of boost.
Old Jan 7, 2002
01civicboirobbclark1 i am sure you could do that but make sure the turbo would actually work and is not all rusted out.
Old Jan 7, 2002
2k2civic's Avatar
Also, if your gonna pick up a used turbo - make sure the car hasn't been sitting for ages and find something with low miles - that way you know the turbo still has some life left in it.
The thing I gotta appreciate about a turbo is that if you were to have a turbo seize or have the bearings burn out or anything, each and every part of a turbo you can buy by itself and/or upgrade.
Old Jan 7, 2002
h2k1ex's Avatar
whoa thanks, now I know why. I was confused because nobody ever talked about that. Thanks
Old Jan 8, 2002
2k2civic's Avatar
Read this
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
meicalnissyen
Sep 22, 2015 06:20 PM
Bricoleur
Sep 9, 2015 12:23 PM
justcruzin125
Aug 11, 2015 09:09 PM
