Engine Performance Modifications Post information/questions about Forced Induction, Nitrous, Engine Building and Swaps here.
Low idle and cut off Honda CIVIC B20 turbo with diktator
Old 08-26-2015
Jaryn is an unknown quantity at this point
Hi Guys
i am new to this forum and hoping to trade information about Honda Civics. I currently have a 98 model Honda civic with a b20 stock internals with a t3/t4 turbo which is running on a diktator management system. I have noticed that when i start the engine(cold) the car idles quite low and if i rev the car a bit, it then switches off. However after driving the car for until it warms up it then idles very high (2000rpm), Could this be the management system that needs to be reset? Please advise if you can, Thank you
Regards
Jaryn
Jaryn is offline
Old 09-02-2015
Re: Low idle and cut off Honda CIVIC B20 turbo with diktator
Hi, I have found the problem, the setting on the diktator management system are way off due to the been standing for so long and the battery dying half the time. A simple tuning fixed everything and 147 wkw at 0.4 bar is awesome.
Jaryn is offline
Old 09-02-2015
drhawkinz's Avatar
drhawkinz has a spectacular aura aboutdrhawkinz has a spectacular aura about
what does that mean?
drhawkinz is offline
Old 09-02-2015
metric numbers mistyped is my guess
sdaidoji is offline
Old 09-03-2015
What does what mean?
Jaryn is offline
Old 09-03-2015
Hi, If you are talking what 0.4 bar of boost, then that is about 5.8 psi.
Jaryn is offline
Old 09-03-2015
drhawkinz's Avatar
what's the 147 wkw? is that like a jigga-watt?
Old 09-03-2015
mikey1's Avatar
a problem with your flux capacitor would be my guess
mikey1 is online now
Old 09-09-2015
Do you think that it could be the fast idle thermal valve that needs to be adjusted? I think i would give that a try and revert when i know the outcome. Also i tuned the car in the past week. Turns out that the ECU settings were way out so that is sorted now. Car makes 253hp at the front wheels, I was advised that if i change the internals i can gain a lot more boost out of it. Anyone know the cost to import conrods and pistons from the states to South africa?
Jaryn is offline
Old 05-17-2016
Hi Guys, I need some advice. I was thinking of mating a b20b block with b16 vtec head and turbo charding it. Will the block handle the turbo and vtec working? or will i need to upgrade the rods and pistons as well the sleeves? I currently have a b20b motor with a bolt on turbo
Jaryn is offline
Pr0n1s
04-30-2015 03:08 PM
Rinzlor
04-24-2015 10:33 AM
jessicakaybby
04-20-2015 12:11 PM
CascadiaBlue
04-18-2015 09:13 AM
dooner24
04-14-2015 07:51 PM
Quick Reply: Low idle and cut off Honda CIVIC B20 turbo with diktator
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
