When my tires shakes......
Rep Power: 0 When my tires shakes......
I was wondering....when im going at high speeds like 90-100...my tires start to shake very bad....i have 16inch rims..and my friend told me they shake kuz there to small.....i was wondering....i been driving for a while now and i wanna know if it might have mess up anything?...how u know wut i mean....
in other words when my tires shakes very intense can it affect anything?....springs,the alinment,etc....thanx
Rep Power: 0 Bigger rims.......thats the funiest thing ive ever heard,,,,,,,anyway,,,,,,,are they aftermaerktet wheels????
theyre probably off balance take em back to the shop and they should rebalance em for free
Rep Power: 0 if you have this new of a car you should worry bout alignement.........only unless you tagged a curb....which hopefully you havent
[IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Rep Power: 0 You know what! I think the problem with aftermaket wheels is that the center of the wheel doesn't fit properly and it doesn't matter if they are ballanced, you'll still get vibration.
Do one thing, jack the car, remove the 4 bolts, once they are removed, check if the tire once in place, has play up and down, Factory tires once you push them in to the wheel lugs it just doesn't have any play 'cause the center hub fits perfectlly in the assembly, do you know what I mean?
What I'm trying to say is that the lugs primary objective is to hold the tire there.
the center hub's primary purpose is to keep the wheel where is supposed to!
Rep Power: 0 if ur tire wobbles.......... u might of tighten your bolts on the rims too tight
try using a torque wrench to balance it out........ u should use 80 lbs of pressure.
Rep Power: 0 although if it was the hub it should shake at any speed.....
balance em.
[IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG]
balance em.
Rep Power: 0 Not necesarily, I used to have aftermaket wheels and they vibrate only at high speeds. If they vibrate at any speed, it might be really bad trust me!
1 Post
Rep Power: 0 I'm used to be a tire installer for quite awhile..
Your wheels are improperly balanced. a 15" wheel for example driving at 60MOH with it being say 25 grams off balance.(the little weights) Will be 13'bs so that's like having a 13'b weight flying up and down every time your wheel rotates. Not at 100MPH.. That's alot more weight which can make your wheels/whole car vibrate almost violently.... First thing I'd do is have someone drive behind you (at lower speeds) and see if the rims are bent in any way. Secondly. If that's not the case.. get em re-balanced. Aligmnet will NEVER cause a car to shake. It will cause a car to pull to either direction. It can cause stabily loss in turns. Or just plain ole Uneven tire wear.
Cheers
Mohawk
Cheers
Mohawk
Rep Power: 0 [IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]too small a tire[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]You friend is a crackhead[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Rep Power: 0 yeh its prolly uneven tire wear...these rims are used...so im thinking of...putting my stock ones in after i take sum pix and post them in the rides.
Rep Power: 0 << yeh its prolly uneven tire wear...these rims are used...so im thinking of...putting my stock ones in after i take sum pix and post them in the rides. >>
why put the pics in members rides with the rims and then take them off[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
SidCivic
10-03-2015 06:00 AM
Touge
09-01-2015 11:25 PM
