NEON LIGHTS DONT FIT......
Old Jan 7, 2002
CiViCsIkNeSs's Avatar
CiViCsIkNeSs is an unknown quantity at this point
i need help !!!!
im tryin' to put my neon light inside my center vents ! Now, i got tha center console and all that off already and i went to put tha neon tube in and it wouldnt fit! i thought tha vents where a single tube but they are double ! it would fit if there wuz'nt that piece there! (tha hazard button) so what i need some advice on is if i should cut tha plastic and make tha vent path a single path so i can fit tha tube in ! would that affect tha way my air comes out ? ( if you guys dont understand what im talkin about, sorry! i tried explaining it tha best i can ! i wish i could take pictures and show them !)
Old Jan 7, 2002
BlueIce2001's Avatar
BlueIce2001 is an unknown quantity at this point
man if i was you i wouldnt start to cut sh@! AN other thing you can try is the neon kit that is made for your headlights cause its just a little light and you can put one in each of your vents!!!!!! but its up to you
Old Jan 7, 2002
tsunamisplash's Avatar
tsunamisplash is an unknown quantity at this point
what size neon did you purchase? an eight inch neon tube is ideal for the available space in the vent.
you WILL however need to crack open that lexan protective tube to get at the actual neon.. i'm not sure if you want to do this, but i did it and it works perfect. i'll post a pic soon enough. no real cutting needs to be done, but you will want toshove the tube done into where the vents fork out and then run the wire back up, out, and around. use some sort of black tape to tack the sucker down and your pretty much set. don't worry too much about the temperature, since there is alot of room for the neon to breath freely and since it almost lays flat, air travelling up through the vents will not be distracted.
if you need more help with this.. both toastyghosty and i have it done and working perfectly. have fun!
Old Jan 7, 2002
thanx !!! i just finished and it worked out perfect ! i remember seeing your post a while ago and remembered that you wrote to remove tha neon from tha tubing, so i did that ! i wuz hoping to go straight across my vents, but as we both know, they're forked ! so i just shoved it all tha way in and taped it down with some black tape! i brought tha wire down through tha bottom or tha 12v outlet (like tha crack in between tha ashtray piece and tha shifter console)! so everything worked out and i guess i ended up doin' jus like you tsunamisplash, but thanx for responding! (i tried to post pix but i dont know how !) but juss to let everyone know it looks sick !
o yea and it iz an eight inch neon !
Old Jan 8, 2002
good s#it, man.. glad to hear everything worked out now if only other people had such good advice in here, eh? haha..
Old Jan 8, 2002
NBPCivic's Avatar
NBPCivic is an unknown quantity at this point
Where did you buy it? I am looking for an 8 inch tube but can't find one. Also, where do you hook the wires too?
Old Jan 8, 2002
Booohahaha's Avatar
BAD MON
nice nice good job
yea i dont see why people keep bashing others
hell when i ask question i just ask them
and i dont want to hear people telling me to go search for them!
its a board! dangit!
Old Jan 9, 2002
I BOUGHT THA NEONS AT KRAGEN AUTO PARTS ! BUT THEY HAVE THEM ALL OVER THA PLACE...
I.E. KRAGEN, PEP BOYS, AUTO ZONE, ETC.
YEA IT KINDA BUGGS WHEN YOU POST SOMETHING TRYING TO GET ADVICE AND SOMEONE STARTS TALKIN' S**T ! BUT SOMETIMES ITS ALL IN FUN ! I GUESS ITS HOW YOU REPLY THAT MAKES IT SEEM LIKE A JOKE OR LIKE A SMART @$$ REMARK ! BUT ALL IN ALL I THINK EVERYONE IN THIS WEBSITE IZ THA S**T AND OUT FOR THA SAME GOAL...TO HAVE PIMP @$$ RIDEZ......
Old Jan 9, 2002
HEY NEORETROMAX, HAVE YOU SEEN WHAT IT LOOKS LIKE ! IT LOOKS SOOOO TIGHT ! IT IS A CRAZY (ANDI THINK) CREATIVE IDEA BUT IT LOOKS PIMP WHEN YOU ARE DRIVING AND YOUR VENTS ARE GLOWIN' ! AS FOR THA WIRES, MINE STILL PLUG INTO THA CIGG. LIGHTER OUTLET (12V) I BROUGHT THA WIRE DOWN THROUGH THA SIDE OF THA CENTER CONSOLE AND... WELL ITS HARD TO EXPLAIN ! BUT IF YOU WERE TO DO IT YOU WILL KNOW WHERE TO PUT THA WIRES AND MAKE THEM NOT SHOW ! IT WUZ ALL VERY SIMPLE ! (OTHER THAN MY LIL' RUN IN WITH THA FORKED VENT) I GOTA PUT UP SOME PIX ! NOW MY MY INTERIOR IS ALL NEONED-OUT! ILL TRY TO GET A DIGI CAMERA AND TAKE SOME PIX!
Old Jan 9, 2002
Booohahaha's Avatar
BAD MON
POST PICS
hahahaha
me wanna see
and prolly thief ur idea too
do it!!
supercivic01
South
Nov 30, 2001 11:27 AM
BiGbRoWn
Bolt-on Engine Performance
Nov 21, 2001 06:17 PM
NukeSilo
Nov 20, 2001 05:17 PM
viper775
Nov 15, 2001 10:54 PM
NukeSilo
Nov 4, 2001 09:37 PM
