DIY install of moonroof visor - not as easy as it looks
Old Jan 21, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
I installed it yesterday, expecting it to take maybe 10 minutes, but i had all kinds of problems. first, the protective tape didnt stick, so i couldnt use it, and ended up with a few scratches in my paint. im gonna use some touch-up paint and fix them, no one will see them where they are, but still annoying. then i had a hell of a time trying to clip the visor on. it wasnt possible to do it the way the instructions said, i had to get the clips on, then try to attach them to the screw and get the nut on, which was very difficult because the screws were so damn short. it took me about an hour and a half before i finished, then another half hour to get the grease from the moonroof track off my car since it got on my hands and i touched the roof a lot getting the visor on.
Old Jan 21, 2002
Daniel420's Avatar
Daniel420 is an unknown quantity at this point
yikes!! It took me 10 min but mine came w/ 3m adhesive tape on the bottom. I cleaned the area, centered it w/ a ruler and put two sticky tabs to mark the spots and pulled of the tape's backing and viola! 10 min
Old Jan 21, 2002
NeoMagus's Avatar
NeoMagus is an unknown quantity at this point
wish me luck, im puttin my visor on my 99 tommarow.
Old Jan 22, 2002
Jimmy24's Avatar
Jimmy24 is an unknown quantity at this point
Well, It took me about 10 minutes too! Just make sure you use alcohol to clean the area where the tape is going to be placed. Hook everything up but loose, this way the visor is installed but you can play with it until you get it centered(using a meassuring tape), then, tighten it up!
You should be set!
Old Jan 22, 2002
Diznavis's Avatar
maybe my clips were too short or bent in too far or something, there was no way to clip them on if they were already attached to the visor, i had to clip them first, then attach them to the visor
Old Jan 22, 2002
UncleB's Avatar
UncleB is an unknown quantity at this point
I took that dang thing off. I think they are stupid.
Old Jan 22, 2002
BlueIce2001's Avatar
BlueIce2001 is an unknown quantity at this point
it took me 10 min also
it should be easy like they said before but everthing on loose so it can be centered
but also i have had it on since i first got my car and am thinkin about gettin it painted the same color of my car just to be differant
Old Jan 22, 2002
NeoMagus's Avatar
Took me 10 mins as well...went fairly well installing.
It helps me in my 99 considering the moonroof in it is not tinted like the 2k1's
Jul 12, 2015 11:54 AM
ZILLA
Jul 10, 2015 06:05 AM
fvckbg
Jul 7, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
ZILLA
Jul 5, 2015 05:24 PM
