autometer shift light
Old Apr 15, 2002
bhaz413's Avatar
Support your local 81
From: In the land of milk and butter, Massachusetts, US
bhaz413 is an unknown quantity at this point
Hi there, I have a auto meter shift light. I have had it for about a year, but never got it to work. Is there any way to find out if it work? I connected it to the neg and the pos side of the battery, but it did not light up. how can i test it to see if it works with out actually mounting it in my car? Also, where is a good spot to wire the neg and pos side of the wires into the car? I was reading the DIY on how to hook up the tach, because it is on the same idea. BUt I do not know how to hook somthing into my fuse box. ANy help would be greatly appreciated. Thanks!
Old Apr 15, 2002
blouisgod's Avatar
Life Begins > 6800rpms
ground one wire (usually the black one) and wire the red into the front end of a fuse (the accessory plug fuse works best because it is controlled by the ignition). hope that helps.
Old Apr 15, 2002
bhaz413's Avatar
<< ground one wire (usually the black one) and wire the red into the front end of a fuse (the accessory plug fuse works best because it is controlled by the ignition). hope that helps. >>
a spare accessory fuse correct? will it be labeled on the fuse box? Also 1 more question, should i just wrap it around the fuse? thanks for the help
97-DX-Lover
Jun 14, 2015 06:07 PM
Blazz
Jun 4, 2015 01:04 AM
cruisers10
May 12, 2015 10:46 PM
bo_red
Transmission
May 3, 2015 09:14 PM
dragonsblood
Apr 27, 2015 12:28 PM
