New Cams
Old Apr 14, 2002
BlueBullet's Avatar
BlueBullet is an unknown quantity at this point
New Cams
I searched for like 2 hours and wanted to know will any dohc cams fit on our civic and if not then which companies make new cams? I was thinking the the older si 98-00 cams should fit. Any help is appriciated. I wanna port and polish but i wanna see if i can get new cams first. Thanks
Old Apr 14, 2002
Vicci4Life's Avatar
Vicci4Life is an unknown quantity at this point
No, the old cams may just fit right on there but they won't work, it's a different engine, I wouldn't try that. AEM makes the part, AEM Cam Gear, check out the parts section, later- joe
Old Apr 14, 2002
LOWBOY's Avatar
LOWBOY is an unknown quantity at this point
Wouldnt you rather have an aftermarket cam instead of a stock one. Last time I checked, most were not as much $$$ and gave better performance gains.
Old Apr 14, 2002
Jon's Avatar
Jon
Jon is an unknown quantity at this point
the dohc cams cannot work on our car. we have a sohc vtec motor so the camshaft has intake and exhaust lobes. on the dohc motor there are obviously 2 camshafts and one has intake lobes while the other has exhaust lobes. Check out Linck'd, they have a port and polish package (~1,650) that includes a new camshaft[IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Old Apr 14, 2002
pr0ph37's Avatar
pr0ph37 is an unknown quantity at this point
there are after market cams out for us. im not shure who has them but from what ive heard crane cams has the best cams around. see if they have some if not pick up a sport compact car, honda tuning, turbo...magazines
Old Apr 15, 2002
ASWZero's Avatar
ASWZero is an unknown quantity at this point
If anyone wanted to try something, try to a head swap with a B16A2 or B18C - assuming you want V-tec. Who knows, it might work.
Old Apr 15, 2002
avenger's Avatar
avenger is an unknown quantity at this point
go learn about engines before you attempt engine work
Old Apr 15, 2002
BlueBullet's Avatar
i know about engines and i thought i would be possible consedering that they look to be about the same displacement and bolt pattern there is no need to get nasty avenger.
Old Apr 15, 2002
PESTLNC's Avatar
PESTLNC is an unknown quantity at this point
Gude (Bullfrog) has cams for our car. They're not on their website though, you'd have to call them.
Old Apr 15, 2002
avenger's Avatar
<< know will any dohc cams fit on our civic >>
dohc cam in a sohc head numbnutz
Old Apr 16, 2002
DriftR's Avatar
DriftR is an unknown quantity at this point
DID ANYONE SAY CAMS? Look into Jun cams. R&D should b finished soon. If u haven't heard of Jun, ur sick.
Old Apr 16, 2002
FiresVTEC's Avatar
FiresVTEC is an unknown quantity at this point
ASWzero and bluebullet.....you cannot but a B series head ( the head contains the cam(s) )on a D block motor. it will not fit. you may try to put an old D head on a block...that might work but i dont think anyone is trying it although it has been discussed here before. i believe the only D series engine with a DOHC is a late eightys integra, someone wanna verify that for me?
ricer_em2
May 11, 2016 08:09 PM
pilebuck13
Sep 21, 2015 10:45 PM
OptimisticWay
Sep 18, 2015 09:37 PM
Juanb24
Sep 15, 2015 12:39 AM
CdnRD
Aug 21, 2015 11:42 PM
