Do we have a DIY on an front upper strut bar??
Old Apr 24, 2002
Dustman380's Avatar
Dustman380 is an unknown quantity at this point
Well......., Do we? If not, could somebody hook a brotha up??
My Shizzit
Old Apr 24, 2002
OPGForce's Avatar
OPGForce is an unknown quantity at this point
just bolt it on. it you have a torque wrench, torque it to spec.
Old Apr 24, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
come on man..
im sorry but i have to flame.....if you honestly cant pop the hood and figure out how to install that, then maybe you should not be attempting it yourself...
peace
Old Apr 24, 2002
Crashoveride's Avatar
Crashoveride is an unknown quantity at this point
It should be straight forward as to how to do it man. But bolt it on, its as simple as it looks. Just make sure your car isnt up in the air when you do it.
Old Apr 24, 2002
R3DF0G's Avatar
R3DF0G is an unknown quantity at this point
Well I know for the neuspeed bar you have to move the clucth resovoir, otherwise it's a cakewalk.[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Apr 24, 2002
2k2civicballer's Avatar
2k2civicballer is an unknown quantity at this point
take off the old bolts on top of the suspension thing, put your strut bar over the rods, bolt it on! your done! voila!
Old Apr 24, 2002
ALLMAN's Avatar
ALLMAN is an unknown quantity at this point
You guys are thinking to close minded......He may be asking can you make a DIY Upper Tower Bar.....which yes I made a Custom Bar...about a year ago!...but if he's not..then just follow the others application methods or search......"upper strut tower bar"..Peace![IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Apr 24, 2002
TEKNIQ's Avatar
TEKNIQ is an unknown quantity at this point
I thought he was talking about making your own alsoif not pity this fool..
Old Apr 24, 2002
pr0ph37's Avatar
pr0ph37 is an unknown quantity at this point
[IMG]i/expressions/face-icon-small-sad.gif[/IMG]
Old Apr 24, 2002
Dustman380's Avatar
First of all , Kiss My a**. second, all I wanted to know was: do I have to jack it up. Do I have to take something off to put it on? I haven't gotten it yet,So I'm just seeing what is involved. Yall are snotty when it comes to stuff. There isn't any reason to flame somebody just because they ask you to share your knowledge. We are supposed to be family.
Old Apr 24, 2002
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
I will say that installing my Neuspeed bar was pretty much like the supplied instructions.
Make sure the car is on level ground and not jacked up. Lifting it up will make the shock towers spread out. A good hint if the bar is not quite lining up.
The hardest part was indeed moving the clutch reservoir, since the bar makes it hard to unscrew the cap. I just drilled a new hole in the mounting bracket and used the stock mounting bolt and hole. All in all it took 30 minutes and that was fooling around. If you have a socket set, I am sure that it will go pretty easy.
I can understand your questions, but once you have the bar, you can always send me an email and I would be happy to share.
Old Apr 24, 2002
Maverick's Avatar
Maverick is an unknown quantity at this point
good instructions. i agree with dustman...some of you should jump off your pedestals and help out the guy. it isn't inconceivable that someone has never done a single mod so therefore the questions. he was just trying to clarify. it's too bad we see more and more of this on this forum. in any case, hope you got it in ok.
Old Apr 24, 2002
Dustman380's Avatar
thanks maverick
Old Apr 30, 2002
Pyro's Avatar
Pyro is an unknown quantity at this point
<< The hardest part was indeed moving the clutch reservoir, since the bar makes it hard to unscrew the cap. I just drilled a new hole in the mounting bracket and used the stock >>
i just zip tied mine down a little lower
Old May 1, 2002
juscallmetoyota's Avatar
juscallmetoyota is an unknown quantity at this point
This board is far from snotty. They have some other boards that will eat you to shreds if you posted this topic.
Steve*
Old May 2, 2002
TOOLOWCIVIC's Avatar
If you use a DC Sports Strut Bar all you need is to bolt it on.
Old May 28, 2002
tummyboy's Avatar
tummyboy is an unknown quantity at this point
all Iam going to say is keep it on the ground and torque the tower bolts to 30 ft lbs. if it is a DC sports bar
GH04si
Apr 15, 2015 08:13 PM
Daniel420
Dec 4, 2001 08:46 PM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
PlatnumBomb
Nov 9, 2001 01:11 PM
andylao
Nov 4, 2001 01:19 PM
