Brake Pad Install Help.. Quick..
Old Apr 20, 2002
DogstyleEX's Avatar
DogstyleEX is an unknown quantity at this point
Ok.. i'm in the middle of installing new pads and i want to know how to bleed the brake fluid a little so i can put the caliper back on since the new pads will stick out more.. thanks
Old Apr 20, 2002
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
umm, you don't bleed the brakes to get the pistons to go back in. All ya have to do is press the piston back in. You might need to use a C-clamp or something similar. In the past, I've used those Quick Grip clamps.
Old Apr 20, 2002
DogstyleEX's Avatar
what if i don't have any clamps that will fit in there and i tried to just push the piston back with my fingers.. it's not moving once so ever.. ??
Old Apr 20, 2002
BAK's Avatar
BAK
BAK is an unknown quantity at this point
I always use a very large screwdriver, or a pry bar to push the caliper back, but be very careful !! And make sure the brake fluid resevior is not filled too high, the fluid has to have a place to go and if the resevior is too full, it will over flow.
Old Apr 20, 2002
avenger's Avatar
avenger is an unknown quantity at this point
go find someone with c clamps... and a piece of plywood, thats the nicest way to do it
Old Apr 20, 2002
TEKNIQ's Avatar
TEKNIQ is an unknown quantity at this point
Quick Grips work well
Old Apr 21, 2002
ASWZero's Avatar
ASWZero is an unknown quantity at this point
if you want to do it the write way, you will need c-clamps, a peice of plywood, brake line pincer, and a 10mm flare nut wrench.
if you want to do it the correct way you will need to pinch the brake line(so no fluid will seep back up the system), open the bleeder screw, and then use the plywood and clamp to puch the piston in. Make sure you do not get brake fluid on your paint, you will be seeing holes if you do. put the caliper back on, close the bleeder screw, remove the pinch, and pump the brakes a couple times. If the pedal drops after you pump the brakes, you have air in the system. Time to bleed the brakes. have fun!
That is not the only way, but you already removed the piston. Do you have the service manual????
Old Apr 21, 2002
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
All you need is a brake spreader. Basically it is an inverted c-clamp. It simply spreads the pads to allow you to install them. Either that or I use a big pair of channel locks and gently squeeze the piston in.
And this method is quoted in the OEM Service manual. "Step 10. Push the piston (A) so the caliper will fit over the pads. Make sure the piston boot is in position to prevent damaging it when pivoting the caliper down."
Star1967
Jun 8, 2015 04:23 AM
masongap
May 26, 2015 07:55 PM
rhvic
May 22, 2015 03:06 PM
bsmiley
Apr 27, 2015 01:27 PM
