Turbo possible after these mods?
Old Apr 15, 2002
PESTLNC's Avatar
PESTLNC is an unknown quantity at this point
I've been saving my $$$ for some big mods as soon as my warranty is up, and I've been wondering...
I plan on getting the Gude head package first, followed by a stroker kit when one becomes available. I want to still be able to run on pump gas, but after those two are done will a turbo be feasible? I read that the Gude package is for N/A only, but the problem could be solved with a new cam...correct? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Apr 15, 2002
randomguy's Avatar
randomguy is an unknown quantity at this point
I've been thinking about the Gude package as well.... In addition to porting and polishing the head, they also mill a little off, which increases your compression to something like 11:1 (not totally sure on that number). Running a turbo with comperession that high and pump gas will lead to lots of little pieces. BUT you could get a new head from Gude until a turbo comes out, then put a thicker gasket in to reduce compression......
Old Apr 15, 2002
DRJ's Avatar
DRJ
DRJ is an unknown quantity at this point
FI will probably work just fine with the Gude package, except for the milling and the cam.
Old Apr 15, 2002
AFlyer's Avatar
AFlyer is an unknown quantity at this point
other than milling the head, you will be good to go with a turbo. you can't mill the head cause, like someone mentioned before, compression that high combined with FI will reduce your engine to tiny pieces.
Old Apr 16, 2002
PESTLNC's Avatar
I wonder if the stroker kit after the head job will put me in the 200hp range. If so, then a turbo wouldn't be neccessary for wasting ricers on the street...but it sure would be nice.
UltraHDGames
Jun 8, 2016 05:16 PM
ricer_em2
May 11, 2016 08:09 PM
HondaGuy7
Feb 22, 2016 01:00 PM
ZoSoIV
Sep 17, 2015 07:17 PM
-HondaFTW-
Aug 30, 2015 10:38 AM
