drop with camber kit??
Old Apr 16, 2002
choiboy19's Avatar
choiboy19 is an unknown quantity at this point
how far can we drop our cars without putting on a camber kit?
Old Apr 16, 2002
pounds's Avatar
pounds is an unknown quantity at this point
which springfield are you in??
btw your probably gonna catch he11 for posting this before searching!!!!!!!!
run...run....ruuuuuuuuuuuuuuuuuun
anything lower than around 1.5inch you should consider getting a camber.
Old Apr 16, 2002
Mapes's Avatar
Mapes is an unknown quantity at this point
aint gonna flame......i got the neuspeed sprots(1.75 drop frnt, 2 in back) the front is aligned to stock specs, but the back is only off like .8 in. i would say anything above 2inches you should check into it, but below 2 you should be fine.....
Old Apr 16, 2002
JBlazeVA's Avatar
JBlazeVA is an unknown quantity at this point
c00
Old Apr 16, 2002
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
Honda recommends that you have only -1 degree camber plus or minus 1 degree. My car stock was almost -1 degree. With the Eibach Sportlines installed, my car registered over -3 degrees. This is way too off and would have been pretty bad on tires. The Ingalls kit allowed me to have the car realigned and now everything is going good.
You can pay 150 dollars and get a good alignment, or you can replace tires maybe twice as fast. In my mind, 150 dollars won't buy two tires much less a full set, so it was an easy decision.
I guess what I am trying to say is if you want to do it the correct way, buy the Ingalls or Eibach alignment kits. If you want to save a little bit of money upfront and spend more later, don't do it. But it is usually cheaper to do it the right way first.
Dave Brabant
20
Oct 6, 2015 12:44 AM
zeshan7616
Sep 15, 2015 12:24 PM
bashea
Sep 15, 2015 04:59 AM
Juanb24
Sep 15, 2015 12:39 AM
Bricoleur
Sep 9, 2015 12:23 PM
