Car Higher in Front than Rear
Old Apr 11, 2002
Phatster's Avatar
Phatster is an unknown quantity at this point
I have dropped my car. Me and a buddy did it. It has been about a month now. I have a slight problem and that is that my front sits higher than the rear. I have 2' springs all the way around as well. The only thing that i can think of is that we cut the bump stops in the back, and thats the only thing that I cant think of that would have made the back lower than the front. Please get back to me on this, with any suggestions thanks.
Seth
Old Apr 11, 2002
pounds's Avatar
pounds is an unknown quantity at this point
after reading your sig. i see that you have a system, and you evidently have a sub box in your trunk...and that is quite a bit of added weight...that may have caused your springs to settle in the rear quicker!
Old Apr 11, 2002
pogi2k1ex's Avatar
pogi2k1ex is an unknown quantity at this point
yes ur system is weighing down the trunk....a few things u can do to resove this.....
1. u could have gone with a set of springs like the neuspeed sports where its 1.75 in the front and 1.5 in the rear...if u put a box in the trunk, the drop should be pretty even
2. get coilovers
3. get rid of the box
4. or just deal with it[IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Apr 11, 2002
nochopstix's Avatar
nochopstix is an unknown quantity at this point
it could be an optical illusion. the front fenders are cut deeper than the back ones. make sense? later
Old Apr 11, 2002
jamesbbh's Avatar
jamesbbh is an unknown quantity at this point
no its really lower in the back ive seen it , wadup seth u punk
Old Apr 11, 2002
crazybluehonda's Avatar
crazybluehonda is an unknown quantity at this point
dropzone 1.8inch drop my civic is higher then the back. much i have a friend who works on frame straightner meters and its true. just bad workmanship!
Old Apr 11, 2002
Hondasport01's Avatar
Hondasport01 is an unknown quantity at this point
My car did that with eibach sportlines... All I did was cut 1 1/2 in. from the end of the coil and it evened it up. Looks good now
Old Apr 11, 2002
Wanger's Avatar
Wanger is an unknown quantity at this point
<< My car did that with eibach sportlines... All I did was cut 1 1/2 in. from the end of the coil and it evened it up. Looks good now >>
ewww, cutting springs j/k
Old Apr 11, 2002
VNlilMAN's Avatar
The Standard One
what kind of springs do you have? i'm guessing some cheap ones. its most likely a combination or that, your system, and it's a 4 door.
Old Apr 11, 2002
dragoon's Avatar
If my car's a stock 2 door and I get eibach prokits, this wouldn't happen to me, right? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Apr 12, 2002
Phatster's Avatar
Thanks to all that have helped me out. I have actually taken the box out of my car and it still stis lower in the back than the rear, but who knows I guess I will just have to deal with it, or just cut the springs or get new ones. Thanks for all the help.
Old Apr 12, 2002
CRAZEDMAN52's Avatar
CRAZEDMAN52 is an unknown quantity at this point
I have a '02 civic EX too. It did the same exact thing as yours did. I put 2" all around. I have studied it time and time again. My guess is that the rear wheel well is not cut as deep as the front one. I dont like it either. I think I am going to get some different springs. Ones that are shorter in the front than in the rear. It just really blows that I wasted that money on some 2" all the way around.
Old Apr 12, 2002
Phatster's Avatar
i feel yah man it sucks big time bad. I hate looking at my car. All my friends make fun of me because they say i am sagging in the rear and just make smart remarks too it and all. it stinks
Old Apr 12, 2002
FamilyMan's Avatar
FamilyMan is an unknown quantity at this point
Try checking out this thread. I had/have the same lower rear problem but have an almost solution for you.
Read this thread...last post
Hope this helps you.
Old Apr 12, 2002
VNlilMAN's Avatar
The Standard One
i'm thinking maybe you guys have progress springs? cause those look like they sag in the rear. one reason why i didnt get them..
Old Apr 14, 2002
RockfordFosgateBwoy's Avatar
RockfordFosgateBwoy is an unknown quantity at this point
dont the H&R springs drop the front 1.75 inches and the rear 1.5?
how could you have such a problem then?
would eibachs help?
I dont know, im gonna be getting srpings this summer and lets just say i have the weight a fairly large male human in my trunk, yes my stereo stuff is that heavy and I'm gonna be getting some seriosu subs soon, W7's or Punch HX2's. help?
RF Bwoy
Old Apr 14, 2002
pmau's Avatar
pmau is an unknown quantity at this point
If you're planning to get shocks, go with konis and they will also correct the problem with having your rear lower than your front. That's what I did. The konis in the rear can either raise or lower your car another 0.5 incles.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
mistermenphis22
Apr 3, 2016 08:06 AM
GH04si
Apr 15, 2015 08:13 PM
usajags84
Apr 10, 2015 09:54 PM
JeffSpeed21
Bolt-on Engine Performance
Nov 4, 2001 12:33 PM
