Painting and re-finishing
Old Apr 24, 2002
DriftR's Avatar
DriftR is an unknown quantity at this point
Painting tips
As most of you guys/gals like to work on your cars like I do, to either save some $$ and accomplish things yourself, I have some tips for when you paint ANY exterior plastic part on your car.
I'm in the process of painting some side view mirrors for a friend. Now if most of you think that all you need to do is 1) prep the part 2) paint the part 3) clear coat the part 4) reinstall the part and marvel at the great job you've done, I have to say you are sadly mistaken. There's more to it after applying the clear coat.
This is what I did with great results, so far.
After you apply LOTS of coats of clear, let it dry for a day or two. You'll notice that it isn't quite as shiny/glossy like the rest of your car and has a rough texture to it too. No need to worry. Go grab some 2000 grit wet/dry sand paper and let it soak in water for about an hour or so so it doesn't crease and cause any deep scratches. Lightly sand it and wipe off the residue as you go along. This will give the surface a VERY smooth feel and dull the finish a bit. Don't sand it too much or you'll sand through the clear coat and then you'll have to start from scratch. Once you're satisfied with how it feels, wipe it down thoroughly. Now get some rubbing compound and a soft rag to bring out the shine. Don't go too crazy with the rubbing compound also because you can also go through the clear coat. You can follow up with 3M swirl mark remover or Meguiar's #9 to even bring out the shine more. But if the rubbing compound brought out the shine then this step can be skipped.
Now put the part aside for about a week so the paint has time to cure and then you can apply a polish/wax.
I'll post some pics later to show how it looks as I'm in the waiting process The thing you have to do is be patient. If you rush around and do a half *** job it won't turn out good. Believe me I KNOW
Hope this helps.
Courtesy Silvr bullet TorontoCivics.com
Old Apr 24, 2002
SWEETRIDE's Avatar
SWEETRIDE is an unknown quantity at this point
Thanks, good tip. Most people make the mistake of not letting the paint dry/harden long enough!
Old Apr 24, 2002
WhiteRiceBoi's Avatar
WhiteRiceBoi is an unknown quantity at this point
big up props to chix wh know their painprocedures =)
u dotn need ot wait that long for curing..about 2 days hsould be enough ina warm environment.... and also i think 2000 is too high a grit, its almost as smooth as paper..use 1500
Old Apr 24, 2002
2k2civicballer's Avatar
2k2civicballer is an unknown quantity at this point
1 days enough to cure. but if you wanna be super safe then go ahead, but otehr than that you were right on
Old Apr 25, 2002
BlueIce2001's Avatar
BlueIce2001 is an unknown quantity at this point
sweet just one question where can i get a paint sprayer??? after that i should be in business and be doin some DIY's
Im just askin
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
carid
Sep 28, 2015 10:13 AM
Sep 27, 2015 11:33 AM
speedlever
Sep 24, 2015 07:18 PM
