Transmission fluid
Old Dec 18, 2004
hotrodcivic2004's Avatar
my civic has no boost
Question Transmission fluid
Ok i did a search and found out a lot about manual transmissions. unfortunatley i found almost nothing on automatic. in my users manual it says that my transmission will hold 2.9 q of ATF-Z1 from honda. but below it it says 'total: 6.0 q'.....so what is it, when i replace my fluid should replace it with 2.9 quarts or 6. i guess i'm confused on what the 6 is referring too.
Old Dec 18, 2004
Sickboy's Avatar
Sickboy will become famous soon enoughSickboy will become famous soon enough
A lot gets held up in the torque converter, so it doesn't completely empty when you drain it. I would drain it and refill it twice over the course of the weekend to get most of that fluid out.
Old Dec 18, 2004
Um yeah there are at least 4 diy posts and 10 more other question posts. It's 2.9, but you need to check the level with the car warmed up to know for sure.
Old Dec 18, 2004
streetglower's Avatar
doing that only drains out the 3 quarts you previously filled. You are not getting the fluid from the torque converter.
6 quarts is when flushing the tranny, 2.9 is for drain and refill.
OptimisticWay
46
Oct 15, 2015 02:16 PM
AirJordan613
General 7th Gen
Aug 2, 2015 08:55 PM
Q-Bert
Jul 19, 2015 09:09 PM
srtlat
Jul 17, 2015 11:53 PM
Jul 12, 2015 11:54 AM
