Electrical Question
Electrical Question
For all you electrical gurus. If you splice a wire so that you can extend it, how do you get the two ends to make a connection again. Meaning, cut a wire in half, now there is a 2" gap between the ends, how do you get them to connect to eachother again. Must be weather proof. Thanks guys.
Use wire taps. They have two grooves for each wire to fit, then you clamp down a metal piece and wrap with tape. Or just wrap the wires around each other. Electrical tape is pretty much fine if you wrap it well enough.
any auto place. They are called wire taps or splices. They're maybe an inch, but what do you mean fill the gap? If you just need to connect wires together but they're not long enough, you need to buy extra wire and splice it to each end.
i solder everything.. it takes like 2 seconds and its fun melting stuff..
just about everything in our cars is 12gauge wire.. you can get that anywhere..
in yer case its understandable... since you have moded every part of yer car that noone would ever think to mess with.. im waiting for you to put a cannon in the trunk
telly telly telly, I was just bout to say that.
Splice, pig tie, solder, heatshrink. Do on both sides and your done.
Soldering is a MUST for any electrical work, no point taking risks in the future and trying to troubleshoot bad wiring.
Originally Posted by TeLLy
What, are you following me around now?
if anything I made the first reply on that El sighting thing :P so i'm not following you.
yeah buy some wire at pepboys or something use a good set of wire dykes strip about 1/2 to 3/4 of an inch off both existing wires, cut about 3" for the middle piece, strip the 1/2 inch off both side of that, now spread the ends of all 4 pieces into v or t shape, twist them togeter with the existing wires, solder, and tape. done.
mjdiaz89
Jun 21, 2016 09:26 PM
sch2cm
Jul 21, 2015 09:58 PM
NoobyKid
Jul 13, 2015 07:53 AM
jferristx
Jul 8, 2015 10:09 PM
