Replacing front let cv axle...
Old Jan 29, 2005
Seabass's Avatar
Seabass is an unknown quantity at this point
Hey everyone, ok im replacing my screwed up cv axle and am trying to find out if its more complicated then just taking the axle off and replacing it with the new, just making sure theres something i dont need to drain first or anything, anyone know? Thanks.
Old Jan 29, 2005
civicdude's Avatar
moving to tech stuff
Old Jan 29, 2005
streetglower's Avatar
you just need to remove you front tire, then remove the nut in the spindle nut, then undo the lower ball joint, then remove the 2 strut bolts so the knuckle will hang forward. Then tap the outboard cv joint threw the knuckle, then with a prybar, remove the inboard cv joint from the tranaxle, making sure not to damage the oil seal. Shouldnt be that to hard.
Old Jan 30, 2005
koolaidman's Avatar
koolaidman is an unknown quantity at this point
heres a easier way
remove tire
32mm take off spindal nute
take off crown nut on ur ball joint
pry it apart
pull on the tri pot do not pull after it or use a pry bar on the tri pot housing
AND PULL
on the spindal
take a punch and hammer and drive it out
Old Jan 30, 2005
Originally Posted by koolaidman
heres a easier way
remove tire
pry it apart
AND PULL
on the spindal
that is pretty much the same thing I said. You can use a prybar on the inboard joint where it connects into the transaxle to pry it out, just making sure not to damage the oil seal.
Old Jan 30, 2005
koolaidman's Avatar
or a pickel fork
Old Jan 31, 2005
Seabass's Avatar
I cant seem to g et the ball joint apart, i tried a pry bar but its not working.
Old Jan 31, 2005
koolaidman's Avatar
how long is ur pry bar...mine is 4 feet long....u need to pry on it like there is no tomarrow if u dont have a long enuf 1
Old Jan 31, 2005
fuchs's Avatar
fuchs is an unknown quantity at this point
Grab yourself a BFH, put the crown nut back on enough to cover most of the threads, and beat the hell out of it 5 or 10 times...the side of the hub that is. That will jar it loose from the hub.
Old Jan 31, 2005
koolaidman's Avatar
talk about destorying ur lower control arm...
KISS= keep it simple stupid
Old Jan 31, 2005
Seabass's Avatar
The side of the hub...you mean the transaxle its connected to or what?
Old Jan 31, 2005
koolaidman's Avatar
hes talkin about hittin ur lower control arm...
Old Jan 31, 2005
well what would be the best way to remove that lower ball joint? I know when removing the outer tie rod from the steering arm, you can give the arm a few good wacks and the tie rod will loosen up to come out. I am assuming a special tool is needed for the ball joint on the control arm.
Old Jan 31, 2005
koolaidman's Avatar
if u do it that way
ur going to need an alignment
the special tool ur talkin about it a pickel fork and a hammer
Old Jan 31, 2005
if u do it that way
What do you mean you will need an alignment if you do it that way? Any time you remove it and then put it back in you will probably need an alignment. Unless you measure the exact area where you took it off and put it back on in the same area. You know what I mean. Usually the pickel fork will damage the boot.
for the lower ball joint I know there is a better tool.
Old Jan 31, 2005
Seabass's Avatar
Ok so i ended up taking the rotor and the brakes off to get the ball joint off, but i damaged the seal. Can i order a new seal from honda or can i get one from a local store? I used a "control arm seperator" and that still didnt work, so thats why i took the disk brakes off and the rotor.
Old Jan 31, 2005
koolaidman's Avatar
u didnt need to...u didnt need the control arm sererator...
U NEEDED A PICKEL FORK!!!!!!!!!
Old Feb 1, 2005
dariusld's Avatar
dariusld is an unknown quantity at this point
I would loosen the spindle nut, before removing the tire. It makes things a little easier.
Old Feb 2, 2005
did you damage the oil seal in the transaxle, or the ball joint boot?
Old Feb 2, 2005
Seabass's Avatar
ball joint boot.
Old Feb 2, 2005
orso's Avatar
orso is an unknown quantity at this point
they sell just the boot. #4 linky
oneheadlight
Apr 29, 2015 11:30 PM
bsmiley
Apr 27, 2015 01:27 PM
thesushiboy
Apr 12, 2015 02:54 AM
ademarco6
Nov 16, 2001 10:19 PM
ademarco6
Nov 12, 2001 06:52 PM
