Broke Exhaust Manifold Bolt Help!!!!!!
CIVIC USER
Rep Power: 0 Broke Exhaust Manifold Bolt Help!!!!!!
I need some help peops, I recently installed my new dc sports header and I overtorqued the middle bolt connected to the engine block and broke the bolt along with the screw stickin out right off. Im stuck. Anyways I have 2 other bolts and 2 screws holding the SUCKER down but Im concerned about leakage in the future. HELP. How can I replace the engine screw that holds the header to the engine???????PLEASE HELP
Turbos, Engines, Chassis and Suspension Tech
Rep Power: 0 First, remove the header.
Then see if any of the bolt is sticking out of the block. If it is grab with vice grips and remove.
If its flush with the head, you might want to have a mechanic look at it.
before trying to remove it, soak it in pb blaster, a lot. whatever you do do not try an ez out. chances are it will just break off and create a bigger problem if you have a little bit of the bolt sticking out, and can fit 2 nuts on it, that would be ideal
muttleytm
07-14-2015 05:31 PM
hayden55
07-08-2015 11:38 PM
