Helpme....hp Header W/highflow Cat
Old Jan 19, 2005
DJ_NILOCIVIC03's Avatar
DJ_NILOCIVIC03 is an unknown quantity at this point
Exclamation Helpme....hp Header W/highflow Cat
can't get it near the head???????? should I bend the engine mounts?
help me please!!!!!
Old Jan 20, 2005
This should tell you everything. However, I remember some people posting about broken engine mounts a while after they cut them.
http://www.7thgencivic.com/forums/sh...hp+race+header
Old Jan 20, 2005
Pb4uGo's Avatar
Pb4uGo is an unknown quantity at this point
Unbolt the front motor mount (2 from above 1 from below, and the cross bolt) and slip the header in from below, easy job. If you are like me and your mount was already ripped to crap at stock power with 40k on it, then just fill it full of 3M window weld and let sit for a day or two to cure. $3 polyurethane mount, and you don't have to replace the broken one .
Old Jan 20, 2005
djmota's Avatar
What he said .
It can still be tight. If it is still not going get a jack under your engine and move it up just a bit.
Old Jan 20, 2005
Exclamation
Originally Posted by djmota
What he said .
Hey U think I'll be able to do it without bendind the engine mount brackets just by loosing some engine mounts and lifting a bit the engine?????
Old Jan 20, 2005
djmota's Avatar
yup. just remove the front mount entirely and raise the engine a bit. Its tight and it goes in, in a wierd angle but it will fit without bending or cutting anything.
Old Jan 20, 2005
DaRk_MauL's Avatar
DaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of light
idd unbolt the front engine mount and then it work
but you have to cut out some metal of the front subframe
Old Jan 20, 2005
thanks man.....I'll do it tonight a I let u know how it went!
Old Jan 20, 2005
djmota's Avatar
good pics.
Old Jan 21, 2005
Hey....I just finished.....its about 2am but I finished........damn I had to push the engine to the back and remove the front engine mount like somebody said......a also unbolted the right mount (passanger side).......I still have to trim that subframe cuz its making my car shake too much.......thanks for all the replays....they helped me a lot the thing that suck is that I get my cat back on tuesday. so, I'm running with just the headers and Highflow cat.......it sounds like **** !!!!!!! ........now I just have to figure out how to cut the subframe where the header its hiting it!!!!!!
Old Jan 21, 2005
What did you'all used to cut that part of the subframe!?!?!?!? like the best and the fastest?
Old Jan 21, 2005
DaRk_MauL's Avatar
Yeah lol i know its a massage car now he!lol
grtz
Old Jan 21, 2005
I drove to my work today and my engine light its not on yet........Im not using the O2 sim yet.....
Old Jan 21, 2005
Logan3024's Avatar
Dam HP, you should have gotten the Kamikazi header man, direct bolt on! You shouldnt install anything that you have to cut/shave in order to make it fit IMO. But yea you need to get an 02 sim asap!
Old Jan 21, 2005
ManUtd0018's Avatar
ManUtd0018 is an unknown quantity at this point
Some people say the o2 sim will make the car faster because it affects fuel mapping, but others say that the sims are simply to keep the engine light off, and that it does nothing to improve horsepower. Your thoughts....?
Old Jan 21, 2005
Well, I was told that the O2 sim was just to fool the computer....so I don't think it should change.......but I don't really know!!!
Old Jan 21, 2005
Does nothing for hp. That 02 sensor is only to tell the ecu that your cat is working. The a/f is calculated from a different sensor.
Use a dremel to cut the subframe (with a metal grinding tool).
Old Jan 21, 2005
Logan3024's Avatar
minus the dremel part.
Old Jan 24, 2005
DaRk_MauL's Avatar
i didnt install that o2 module the engine light went on sometimes and then back of
and now it doesnt light up anymore so!
Like gearbox says it does nothing fo hp it just to fool you ecu that cat is working
grtz
Old Jan 24, 2005
Bmkarr's Avatar
Bmkarr is an unknown quantity at this point
i have the same thing you do on my car the light will still come on but only if you race for about a day... when i say day i mean off and on all day long. the light will then come on but if you drive like a grandma (shifting @ 3k) then the light will go off. ive had mine on for about 3 months now and i dont have sims yet. the light will come one but dont freak like they said its just your o2 sensors
UltraHDGames
Jun 8, 2016 05:16 PM
HondaGuy7
Feb 22, 2016 01:00 PM
jdh022764
18
Nov 3, 2015 06:44 AM
Luluharp
Sep 27, 2015 11:56 AM
anubis62
Sep 27, 2015 12:56 AM
