Oil pressure gauge reading
Old Jan 30, 2005
VietScouty's Avatar
VietScouty is an unknown quantity at this point
Question Oil pressure gauge reading
I want to know what is the normal oil pressure reading. They say if its too low or too high, theres something wrong. Thanks.
Old Jan 30, 2005
ty.barrack's Avatar
ty.barrack is an unknown quantity at this point
I don't know, but It can vary a bit depending on your oil weight, if you have a high performance oil pump and such. As I recall the oil pressure in my 69 bug running a 1.9 liter engine is 60 PSI until the engine reaches normal temp of 175 degrees, then it drops to 40 on the freeway, and about 20 at idle.
Old Jan 30, 2005
koolaidman's Avatar
koolaidman is an unknown quantity at this point
average for all cars
10psi for every 1k rpm
anything under 15 psi ur pump is taking a dump 12 ur engine is going to need to be rebuilt
Old Jan 30, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Full temp idle, about 15 PSI
Full throttle, redline, 95 PSI
Cruising in 5th at highway speed ~60 PSI
Old Jan 30, 2005
koolaidman's Avatar
thanks for specs
Old Jan 31, 2005
VietScouty's Avatar
Thanks guys! So normal is around 30 to 60 psi then.
Old Jan 31, 2005
koolaidman's Avatar
this is what it should be after warm up
Xuhme
21
Aug 7, 2023 03:40 PM
RIPSAW
Nov 6, 2015 04:36 AM
jbander
Jun 4, 2015 05:56 PM
Supramk3
May 11, 2015 07:55 PM
Chronic_issues
May 8, 2015 05:40 PM
