Rear 6x9 install?
Old Dec 30, 2002
Diemos's Avatar
Diemos is an unknown quantity at this point
Rear 6x9 install?
Okay I know there are lots of posts, and I am actually using this DIY to install my explods. But I cant figure out what number 4 is refering to. A lot of these DIY do not include much detail. And I dont know what they are talking about. Pillar rimpanels?????? Where the heck are the "piller rimpanels" I went to the dealership (30 minute drive) and they were absolutly no help. Does anyone know how to get this in?
http://www.7thgencivic.com/forum/messageview.cfm?catid=21&threadid=55493&highlight_ key=y&keyword1=rear%20speakers
Old Dec 30, 2002
SLeePeR012's Avatar
SLeePeR012 is an unknown quantity at this point
I kno exactly how u feel mna. I went through this about 3 weeks ago and I was clueless also. Refer your questions to the proper forum FIRST.
THe Pic 4 is REALLY REALLY REALLY REALLY BAD ANGLE.
It's so freakin easy its hilarious. I don't kno why he had to take an 'overview' of the trunk cuz it makes it look like the plastic tabs are anywhere.
They are accutally tabs that connect the plastic panel to the metal surface of the rear panel assembly.
This is wah you should do to find it easily:
Open the trunk and sit in it. Have a pillow in handy and lay it on the metal that is like a divider between the seats and the trunk. If you don't see this big metal bar then you havnt taken your seats off cuz the seats are connected by bolts ON this metal bar. So now lay on your trunk and have your head on the pillow (unless you dont wanna use a pillow but then it gets to hurt like hell cuz its metal) Have your feet dangeling if you are tall and you should see the 3 clip tabs divided evenly about 1 feet apart form each other from one end to the other. TO take em out you jus grab one end and pull down it should come off wit little force.
If you cant find it still, Im sorry.
But if DO PASS THIS LEVEL read the following:
Since you ar ein the trunk take off the harness for the 3rd brake light. (located middle of trunk)
Next take off each rear pillar, start from the corners, its much better and if you cant take em off use a knife and pry it (thas wha I did and it worked like a beauty!) (I pry everything off my car with a knife, cuz it doesnt scratch nuttin like a thick screw driver and it's really flexible!)
Next jus start peelin off the plastic panel away from the metal, jus keep pullin and pullin and pullin....and pull some more.
Once this is off pull it away enuff for you to have some room to work with the 6x9s.
THe bolts are 8mm's that you'll need to take off the 6x9s. I had to get a special wrench for one bolt cuz its all the way in the back where the rear window is, and a socket wrench will NOT FIT. I don't have wrenches only sockets so I had to pay a lot for a stupid wrench
Once all of this is off keep the bolts in a safe safe place! (I lost 2 and they are 3 bucks each at Honda)[IMG]i/expressions/moon.gif[/IMG]
Go from the bottom (inside the trunk) and cut the two wires that are powering and grounding the speakers. Cut so they have some slack, So basically cut closest to the speakers.
Now remove the speakers and install new ones if your trunk balancing bar is in the way Im sorry but I cant help much there. I jus pulled and yanked with my hammer untill it snapped off. Thas all I can tell you.
Now jus wire the new speakers with a wire connector and re-bolt it and put everything back!
GOOD LUCK!#@$[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Dec 30, 2002
Diemos's Avatar
no no, not picture 4, step 4. I cant find where to go with this step. I know where those tabs are, I saw them when I first open my trunk and I was like oh this will be easy to install. Ill go buy speakers. So I went and bought them. Little did I know.... anyways, STEP 4 is what im looking for. Cuz I cant go on, i just dont know what to do for that step
Old Dec 30, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
http://www.madstatic.com/2k1civic/diy/rdeck/
Old Dec 30, 2002
Diemos's Avatar
Quote
[hr]Originally posted by: ak
http://www.madstatic.com/2k1civic/diy/rdeck/[hr]
omg, that DIY is WAY better than the one I was using. Fortuantly SpoonSport help me out, and I was able to figure it out. You know you have to take a lot of stuff out, Id like to see someone steal my speakers....
Old Dec 30, 2002
dazdncnfusd's Avatar
dazdncnfusd is an unknown quantity at this point
All I know is damn thats alot of work to put in a pair of f-ing speakers.....I used to have a camaro and it took all of 10 minutes to replace the rear 6X9's, take out 8 screws on each side, hook up speaker and put the screws back.....kazaam,you were done....there was no taking the whole damn seat out crap and having to lay in the trunk.....I love my civic and all but i just wanna take a ratchet to the guy's head who designed that rear deck [IMG]i/expressions/face-icon-small-mad.gif[/IMG]
Old Dec 31, 2002
Bellz's Avatar
Quote
[hr]Originally posted by: Diemos
no no, not picture 4, step 4. I cant find where to go with this step. I know where those tabs are, I saw them when I first open my trunk and I was like oh this will be easy to install. Ill go buy speakers. So I went and bought them. Little did I know.... anyways, STEP 4 is what im looking for. Cuz I cant go on, i just dont know what to do for that step[hr]
If you're referring the the DIY that I wrote, I got those instructions from Crutchfield's included instructions when I got my speakers. I didn't think anyone had written a rear speaker DIY yet, so I typed it up for you guys.
#4 is talking about the pillar covers above the rear deck. They just pop out with clips. You might get the deck out with only 1 pillar piece removed, but it's easier with both of them out. The tabs in Figure 4 just flop open and they're only purpose is to tie down the deck to the bodywork. I assume to limit some of the rattling.
I didn't take a lot of pictures, since I thought the instructions were simple enough to follow. I may add more pictures soon.
Old Dec 31, 2002
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
Quote
[hr]Originally posted by: dazdncnfusd
All I know is damn thats alot of work to put in a pair of f-ing speakers.....I used to have a camaro and it took all of 10 minutes to replace the rear 6X9's, take out 8 screws on each side, hook up speaker and put the screws back.....kazaam,you were done....there was no taking the whole damn seat out crap and having to lay in the trunk.....I love my civic and all but i just wanna take a ratchet to the guy's head who designed that rear deck [IMG]i/expressions/face-icon-small-mad.gif[/IMG][hr]
i feel you onthat
i drove around with mine off for a couple days b4 i pu tit back on
i was goin to paint it since i had already took it out but never did
one thing thou..i left a screw up in there so now it rattles around when the bass hits hard.
i'll get back around to it when i warms up a little
rtachs
Jul 16, 2015 05:32 PM
S.Klinck
Jun 11, 2015 10:27 PM
edgenet
Apr 28, 2015 07:49 PM
ej8
Apr 13, 2015 06:36 PM
CIVIC9782
Nov 3, 2001 10:33 PM
