running lean
Old Dec 24, 2002
chefjnr's Avatar
chefjnr is an unknown quantity at this point
running lean
noticed today that I run lean when using nitrous, what do I have to do to fix this?? Do I need one of those AFC fuel controllers, if yes, isnt there one out there that has VTEC adjustment controller built in to it, I thought I read about obe of those posted here somewhere.
Old Dec 24, 2002
Sweetpants's Avatar
Sweetpants is an unknown quantity at this point
well im not sure if u need one, but Apex makes one with the VTEC controler. Its the V-AFC.
Old Dec 24, 2002
S2000man01's Avatar
O RLY
how big a shot are you running?
Old Dec 24, 2002
sspem2's Avatar
em2
what does it mean your running lean?[IMG]i/expressions/face-icon-small-confused.gif[/IMG] im still learning about cars so bare with me.
Old Dec 24, 2002
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
Running lean means your not getting enough fuel. Running rich means too much fuel.
Old Dec 24, 2002
civichx81's Avatar
civichx81 is an unknown quantity at this point
damn i start to run lean after 5 or 6 seconds on nitrous.try lowering your nitrous jet size....
Old Dec 24, 2002
S2000man01's Avatar
O RLY
you generally want to run 12:1 or 13:1 air/fuel mixture at MOST. any higher and you are too lean, and this can lead to detonation.
Old Dec 24, 2002
S2000man01's Avatar
O RLY
you could also go wet shot, which injects nitrous AND fuel into the mix, helping you keep the mixture good. But I'd only do that if you're running at least a 75 shot.
Old Dec 24, 2002
civichx81's Avatar
how does detonation sound like??? i dont want to have it happen. ok..im running 80 shot and around 5 seconds after being on nitrous, my car starts to slow down and sounds funny like its bogging or something.
Old Dec 24, 2002
S2000man01's Avatar
O RLY
yeah, that's very bad. I suggest you look into that, and turn down your shot. there are some nitrous systems that will automatically cut the nitrous shot if you run too lean. you may also want to look into that.
Old Dec 24, 2002
chefjnr's Avatar
I'm running a 50 shot (for those that dont know, this is the max you can run on a stock civic ex w/o getting a larger fuel pump and internals, a 75 shot will kill your engine!!!)- anyway, it is a wet system, the question was for those that have a afc controller- will the v-afc allow me to adjust the fuel curve to supply more fuel when using the nitrous
Old Dec 24, 2002
2001civ's Avatar
2001civ is an unknown quantity at this point
yeah it will. V-afc if you have the v-tech and S-afc if you don't.
Old Dec 24, 2002
S2000man01's Avatar
O RLY
well since he's posted this question in here again, im locking this one.
themechanic
Lighting
Feb 2, 2018 09:23 PM
Blazz
May 25, 2015 10:56 PM
JoeB16
61
Oct 16, 2003 07:58 PM
vietnam
Detailing
Feb 19, 2002 09:34 PM
ripper
Bolt-on Engine Performance
Jan 28, 2002 01:34 PM
