Chipped center ring or alignment?
Old Jan 6, 2003
CivicRacer5's Avatar
CivicRacer5 is an unknown quantity at this point
My center rings are chipped and stuff and in kind of bad condition, would that cause the wheel to shake or do i need an alignment?
Old Jan 6, 2003
DRJ's Avatar
DRJ
DRJ is an unknown quantity at this point
Are you talking about hub rings? If so, a damaged one can cause vibration in the wheel and probably isn't too safe to use. If the problem wheel is in the front, a temporary solution would be to swap the ring with an undamaged one from the rear.
If that doesn't work, then either tire balance or alignment may be your problem.
Old Jan 7, 2003
How would the alignment cause the wheel to shake? Also if that is the case would just a front wheel alignment fix it or would i have to get a 4 wheel alignment?
Old Jan 7, 2003
2Hottie's Avatar
2Hottie is an unknown quantity at this point
Check to make sure the wheels are properly balanced...that could be 90% of your problem there....
2Hottie
Old Jan 8, 2003
Pinoy3LeR's Avatar
Pinoy3LeR is an unknown quantity at this point
i agree with 2hottie, have your wheels balanced,improper wheel balancing shakes your whhels
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
solarpunk70
Apr 12, 2016 11:43 AM
Wariogamer
Sep 29, 2015 09:49 AM
carid
Sep 28, 2015 10:13 AM
ttamrekab
Sep 28, 2015 01:22 AM
