Turbo Questions...
Old Jan 2, 2003
VTECnique's Avatar
VTECnique is an unknown quantity at this point
Turbo Questions...
A few questions here. i did a search...
1- cost of install?
2- Kits that are out?
3- What comes in the kit, and will i need to buy extra stuff?
4- VTEC controller, boost controller, etc.
I would like only the people with turbos to reply. I wanna do this by springtime. I wanted to do the Turbo Performance kit, but should i wait for Rev hard?
Old Jan 2, 2003
cambo's Avatar
I wish I was asian
well i dont have a turbo, but i can tell u some things...
1- some ppl have spent 4-8 grand
2- most have been custom set-ups so far
3- see #2, a turbo manifold would also be needed to be made. (sell ur header when u do this)
4- def. get a boost controller as well as a turbo timer. VTEC controller would be optional.
Old Jan 2, 2003
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
if your running a turbo on a d17 you dont need a vtec controller....the vtec aint enough to be called vtec....
Old Jan 2, 2003
Toretto's Avatar
Toretto is an unknown quantity at this point
to tell gyou right now, labor will cost you alot of money and some time.
most performance shops will charge $45-60 an hour.
start getting the main things first.
then start piecing it 2gether until you all the pieces to the puzzle.
get your manifold made.
get a Turbo.
get a blow off valve.
intercooler if your running one.
get all your pipes made.
and the key thing is getting Fuel to the engine so it dont burn lean.
and yes if your VTEC then get the VAFC!!
if your not then get the SAFC!!
Old Jan 2, 2003
MrCool's Avatar
MrCool is an unknown quantity at this point
try searching for my turbo setup thers a lot of info in that post
Old Jan 2, 2003
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
Quote
[hr]Originally posted by: VTECnique
1- cost of install?
I would like only the people with turbos to reply. I wanna do this by springtime. I wanted to do the Turbo Performance kit, but should i wait for Rev hard?[hr]
1- you're looking at around $6k installed by a shop and tuned. You can get a lot cheaper if you do it yourself, but it's still gonna be expensive, and this is not a simle turbo install.
2- None worthwhile. The Turbo-Performance kit is absolute crap, subpar fuel management and the manifold was of horrible design and quality. Tony at Jotech ordered one for my turbo project a while back and we ended up sending it back, the manifold would crack in less than 6 months.
3- Depends on the kit. You will always need extra stuff, as turbo kits never come with clutches, rarely come with all the gauges you need (EGT, Boost, Fuel Pressure, Oil Pressure), and rarely come with a boost controller. Also be careful, some kits (when one comes out for our car) use not-so-good quality wastegate and blowoff valves, and offer something like a Tial upgrade, my advice would be to do that if you can. Better to spend more money and do it right the first time, than have your wastegate stick, boost creep up to about 15psi, and blow your engine.
Search under my user name for the thread, I believe it's in Member's Rides Talk now, I posted pictures and details of my turbo installation.
Old Jan 2, 2003
ChEe12iO's Avatar
ChEe12iO is an unknown quantity at this point
you might as well save up for a k-series swap. you'll get better gains for the amount of beans you're going to spend. you could also turbo it later if you wanted to which will probably put you to 250-260 midrange at the wheels... just my $0.02.
Old Jan 2, 2003
Hawk's Avatar
You boost, I-VTEC
Quote
[hr]Originally posted by: ChEe12iO
you might as well save up for a k-series swap. you'll get better gains for the amount of beans you're going to spend. you could also turbo it later if you wanted to which will probably put you to 250-260 midrange at the wheels... just my $0.02.[hr]
im gonna go ahead and agree with him. i mean if you do a k20 you can have this. Cybernationmotorsports.com
Old Jan 2, 2003
Grey's Avatar
DIY King
Quote
I'm leaning more and more towards this approach myself.
Oh well, might as well do it right the first time.
Old Jan 2, 2003
VTECnique's Avatar
i wanna do a little bit of speed cuz i want a more show type car. should i just do nos for now then do a turbo when a descent kit comes out?
Old Jan 2, 2003
Nuts's Avatar
Nuts is an unknown quantity at this point
not many people think aobut this but the K20A2 swap would be require less mantenance and its just a regular engine, the turbo wears it down. i'd do K20A2. start off with good base power which is eaqul to a turbo for us at 8 PSI.
Old Jan 2, 2003
Nuts's Avatar
and now that the motor mounts are out it won't be as much.
Jaryn
May 17, 2016 02:52 AM
HondaGuy7
Feb 22, 2016 01:00 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
-HondaFTW-
Aug 30, 2015 10:38 AM
justcruzin125
Aug 11, 2015 09:09 PM
