sneaky pete NOS nitrous question
Old Jan 11, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
hey can i ask u guys something bout nos, i am getting the sneak pete nos, and for engine mods i only got aftermarket intake and dc tcs cat, is that ok for such a small boost, like 1/10 of a second boost. compare to 50 shots its lot smaller, and safety...is it gonna be an issue? do u guysprefer me to get any mods before installing it?
Old Jan 11, 2003
Vesper's Avatar
Vesper is an unknown quantity at this point
you should do some work on the engine internals. ie. rods pistons valves. and a performace head gasket.
it also would be nice to get a intake manafold. you know some thing not plastic.
you can do it with what you have but it would be a lot safer to upgrade.
Old Jan 11, 2003
DarrenA's Avatar
DarrenA is an unknown quantity at this point
Why don't you just get a full nitrous kit? A sneaky pete system just doesn't seem worth the money to me. Oh well its your ride, but yeah you should be fine as fas as engine tolerence. Some a running 50's with the same thing. I'm not too sure if a sneaky pete application is even available for our cars. I thought they were like placed above carbs on like old muscle cars. I don't really know how it works on fuel injected car.
Old Jan 11, 2003
Nuts's Avatar
Nuts is an unknown quantity at this point
you can run sneaky pete with completley stock internals. its a very very small shot. it'll feel like a i-VTEC when it activates. its safe to activate in 1st also. my friend put it on his stock 00 civic dx and it felt like a VTEC kicking in.
Old Jan 11, 2003
Logan's Avatar
Logan is an unknown quantity at this point
Quote
[hr]Originally posted by: iluvbritney
hey can i ask u guys something bout nos, i am getting the sneak pete nos, and for engine mods i only got aftermarket intake and dc tcs cat, is that ok for such a small boost, like 1/10 of a second boost. compare to 50 shots its lot smaller, and safety...is it gonna be an issue? do u guysprefer me to get any mods before installing it?[hr]
1/10 of a second? That's an engine fart. [IMG]i/expressions/laugh2.gif[/IMG] A lot of people claim the use of nitrous oxide to be destructive to engines and even I have been ignorant before and jumped on the anti-NOS band wagon before doing some research on it. After further investigation, I've actually found that nitrous oxide will not cause excessive wear or destroy an engine if applied properly. I'm sure there is probably a technical support line you can call (the manufacturer of that particular system) to find out what the safest application would be for your car with your current mods. I know NOS (Holley Performance Brand) tech line is 714-546-0592... One thing I would seriously recommend is forged aluminum pistons and retard ignition timing...and they might also suggest a higher flowing fuel pump. That is definitely sufficient.
Old Jan 11, 2003
yea i might give them a call and do some research on those products....yea i have to jet the carb lil richer for the sneaky nos
Old Jan 11, 2003
Nuts's Avatar
yes if you go 50 shot you should modify your ignition and fuel system. a general rule for determining which size shot to use is 40%-50% of the engine's factory horsepower rating.
forged aluminum pistons are one of the best modifications you can make. retard ignition timing by 4-8 degrees (1 to 11/2 degrees timing retard per 50 H.P. gain) <-----i read that somewhere and i'm not to sure about that fact, anyone can help me out?. spark plugs would also be a good idea in upgrading.
Old Jan 11, 2003
yea its 20 shots i think for the sneaky pete. so about this jetting the carb lil richer, is it gonna be anything problem?
Old Jan 11, 2003
CivicRicer02's Avatar
CivicRicer02 is an unknown quantity at this point
what a waste of money
Old Jan 11, 2003
i know its kinda waste of money, but think about how much money a person have to spend on mods preping for 50shots+, like i said i dont squeeze everyday...i just want it there and be prepared[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 11, 2003
TRIPLExRATED's Avatar
TRIPLExRATED is an unknown quantity at this point
OK, I have a 50 shot on my miata with a 108,000 miles on a stock motor and a rear main seal leak and it is just fine. So running a sneaky pete system will not hurt your car. Like the rest of them said it is better to be on the safe side and forge your pistons and stuff but that is for a 75 shot and above. Also it is recommended to get colder plugs and run 92 or higher octan gas. Me personally I dont run colder plugs just the higher octan gas. When I get my turbo in I am defentily going to rework the motor so I dont blow anything. But if you are gonna run a sneaky pete system you are fine, just run a higher octan gas and you will be fine but if you want to be on the safe side just get colder plugs.
Old Jan 11, 2003
good tip...i'll c wat i can dig up
Old Jan 11, 2003
i dontlike the plastic intake iam scerrred it going to crakeeeee
Old Jan 12, 2003
yea man i have fipk gen 2, its plastic too
Old Jan 12, 2003
so basically turning the jetting the carb little richer means the car will be louder to cover up the nos right?
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
junkyardguy
Sep 2, 2015 06:07 PM
martinsmartin
Aug 15, 2015 07:34 PM
