I need help THIS INSTANT: THIS IS VERY VERY IMPORTANT! (about s-afc and ecu wiring)
Old Nov 14, 2002
SLeePeR012's Avatar
SLeePeR012 is an unknown quantity at this point
Hey guys I need help RIGHT THIS INSTANT!!!
I started to do my APEXi S-afc and I accidently cut my throttle sensor wire.
I also did not use the bottom connector I used the main harness (the one you don't slid out, it's up in front)
I don't think it matters much because it's the same wire I believe so anyways it's really really hard for me to re-connect it. I then started my car because I felt really tired and see if it'll be ok in the morning. It worked fine but the idle was really bad, obviously the throttle sensor. So I connected it as best as I could and started her up, it was the same. Then after a moment I started her up and nothing. But 2mins before when the wire wasn't connected at all it started, but now it doesnt start with or without the wire connecting.
My friend tells me I coulda blew my throttle sensor wire, but how is that possible?
I think it's jus that it's not connected well and that if I use 12v wires to connect the two split ends it'll be ok.
I also did NOT FINISH installing the Safc.
IF ANYONE HAS ANYTHING THEY CAN TELL ME MY AIM IS - SpoonSport12
PLEASE I am scared, if you have any information tell me on this thread. THANKS A LOT!
Old Nov 14, 2002
Gryphin's Avatar
00 Hatchback Owner
sorry wish i knew more about wiring [IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Old Nov 14, 2002
SLeePeR012's Avatar
Doh!
The 12volt won't work because the wires in ecu are accounted by guages not volts...
come on anyone....please.......[IMG]i/expressions/face-icon-small-frown.gif[/IMG][IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Old Nov 14, 2002
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
tap the end of the wire with the voltmeter and try starting your car... If you get no voltage, then you know where your problem is.
Old Nov 14, 2002
Boosted2k2's Avatar
Does your engine not turnover or does it just not do anything?
Old Nov 14, 2002
SLeePeR012's Avatar
I dont got volt meter. and the engine doe snot turn on
I think I got an idea tho how does this sound:
I reset ecu put back the wire as best as possible and start it...you think it'll be ok?
ALSO, NOT FINISHING THE AFC, does that make a differance?
Im asking that because after wha happened im scared outa my mind.
Old Nov 15, 2002
SLeePeR012's Avatar
It's official, i f**ked up.
I butt conncted the wires and reset the ecu
Still won't start.....
Anyone help me out[IMG]i/expressions/face-icon-small-sad.gif[/IMG][IMG]i/expressions/face-icon-small-sad.gif[/IMG][IMG]i/expressions/face-icon-small-sad.gif[/IMG]
Old Nov 15, 2002
SLeePeR012's Avatar
Ok now it will start but sputters big time.
def the throttle body sensor, but the wire is hooked up with a butt and it's pretty good on there.
I think it's the way it's hooked on there, it's not back to original with the connecter.
Anywayz, you think I mite of made it bad by starting it while the line was disconnected? Cuz it started even when the wire was disconnected, it accutally started better than is now when it was connected.
LET ME TELL YOU THIS:
THE ECU IS A VERY VERY COMPLEX WORLD......DO NOT JUS ATTEMPT IT, I LEARNED THE HARD WAY.
Old Nov 15, 2002
OMega's Avatar
OMega is an unknown quantity at this point
Disconet the sensor and get the ohm reading for it. Post it so we can see if its in spec. You mite just have a bad connection. Your always better of spliceing the wire with those 3m connectors. When I cut a wire I always soldier it if I can...
Sorry for spelling just woke up.....
Old Nov 15, 2002
PESTLNC's Avatar
PESTLNC is an unknown quantity at this point
If I remember correctly, the TPS sensor is basically a resistor. By using a "butt" to connect the cut wires you may have increased the resistance so the ECU never get's a signal that's "in-range". Take off the connector and splice the two wires together...then solder it. Hopefully that'll do it.
Old Nov 15, 2002
SLeePeR012's Avatar
Thanks for the input.
I resetted the ecu and ran with it for a while it was sooooo nasty.... I was cryin the whole time.[IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Then afterwards it ran pretty back to normal after shut down.
But I think I can still feel it loose and my check engine light is on.
I'll see how it goes tomorrow Im gettin a pro to put it on no more of that for me.
Old Nov 16, 2002
PESTLNC's Avatar
Whenever the ECU detects a problem it will display the check engine light. It'll stay illuminated until it is reset. Even if you've fixed the problem the check engine light will stay on because the codes are stored in memory.
BootyDo
Jun 21, 2016 03:45 PM
JUNITO
Jul 9, 2015 08:36 PM
aultman1990
Jul 9, 2015 08:27 PM
robbie374
Jul 7, 2015 02:56 AM
Aball93
May 16, 2015 10:11 AM
