O2 sensor....What wire is the signal wire
Turbo Member
Hey I searched to try and find the answer but different people are saying different things. Im trying to hook up my air/fuel gauge and some pole say its the black wire on the first O2 sensor and them some other people are saying that its one of the 2 white wires, then someone else says that one white wire actualy has a grey stripe and that I need the all white one. Well Both my white wires look exactly the same. So can someone w/ te electrical chart help me out? [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
I just checked outside to see where I tapped mine, its all taped up so i couldnt see which wire. I dont remember which wire it is but i think its the black one. If the two white wires are the same then i dont think it'll be the white cause i dont remember running into trouble about picking a wire between two identical ones.
Im sorta remembering it only having one white wire. Dont look at the wire coming from the O2 sensor. Look at the wires after the connector. But still im [IMG]i/expressions/face-icon-small-confused.gif[/IMG] ...if no one can give you straight up answer, ill unwrap the tape on mine and ill check for ya
lol ok i just went and sliced all the wires and u have to slice it into the black wire.... on eather o2 sensor i got mine on the black wire on the o2 sensor thats on the header hope that helps!
Turbo Member
Thanks guys, hey is the gauge supposed to keep sweeping back and forth like that? It never stays in one spot, so I have no clue if im running rich, or lean, or what not.
JUNITO
Jul 9, 2015 08:36 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
