K&N FIPK???
Old Nov 16, 2002
CivicRacer5's Avatar
CivicRacer5 is an unknown quantity at this point
K&N FIPK???
I installed it but it was a very tight fit to get the rubber peace into the heat shield that the filter is connected to and it is not lined up perfect with the throttle body, what can i do to fix this??
Old Nov 16, 2002
cambo's Avatar
I wish I was asian
didnt u already start a tread about this? or is jus me?!
Old Nov 16, 2002
No i started a thread on how awesome it is, but i noticed tonight that it isnt fitting flush with the throttle body and needed some advice!
Old Nov 16, 2002
Black02's Avatar
Black02 is an unknown quantity at this point
I had to trim mine because it was too long, It wasn't a big deal.
Old Nov 16, 2002
Aaggie77's Avatar
Aaggie77 is an unknown quantity at this point
Post some pics of this when you are done. I would really like to see what it looks like when it's installed.
Old Nov 16, 2002
Not the trim the rubber piece that the intake tube goes into, and the filter connect to, that goes in the hole in the heat shield it was a tight fit and caused the tube not to line up perfect with the throttle body, so i had to force it over but it still isnt flush with the throttle body??
Old Nov 17, 2002
white2K2EX's Avatar
I sure wish my car was newer
I installed mine this afternoon, all I can say is, play with it to make it fit. Thats what I had to do. Mine is an automatic transmission though, so I don't know if there's any difference. If you put the rubber piece all the way into the heatshield, the tube should fit firmly into the throttle body. Maybe mess with the brackets? It lines up sort of at an angle (the heatshield) so if its not aligned correct at the bolts, this could throw it off. Thats my only guess though. Mine fit perfectly.
Old Nov 18, 2002
Krepoort's Avatar
Krepoort is an unknown quantity at this point
Quote
[hr]Originally posted by: Aaggie77
Post some pics of this when you are done. I would really like to see what it looks like when it's installed.[hr]
I posted some pics back on the original group buy thread, but here it is again.
-Kre
Old Nov 18, 2002
Did you have to cut the rubber tube that connects to the intake manifold and the intake tube??
Old Nov 18, 2002
Krepoort's Avatar
Yeah. I cut about an inch off. Just enough so it fit perfectly without any arch.
-Kre
Old Nov 22, 2002
timcivic's Avatar
timcivic is an unknown quantity at this point
got a question?
would one of those straight across tower bar fit if i had the FIPK on ?
would it be in the way...?
Old Nov 22, 2002
CapYoda's Avatar
Escaped Convict
Quote
[hr]Originally posted by: timcivic
got a question?
would it be in the way...?[hr]
you may want to adjust it a bit to fit.. but its possible...
Old Nov 22, 2002
white2K2EX's Avatar
I was told the only bars that fit are the Neuspeed and DC versions.
Old Nov 23, 2002
timcivic's Avatar
But from what i see in that picture..it seems like only neuspeed could fit...
cuz the DC one seems like it'll hit the heat shield...
what do u guys think?
Old Nov 23, 2002
CapYoda's Avatar
Escaped Convict
yeah the DC one may hit the heatshield..... better ask around some more. someone's bound to have the DC bar with the FIPK...
rzc
Bolt-on Engine Performance
17
May 15, 2003 04:57 PM
CapYoda
May 12, 2003 01:57 PM
Friedrice
Mar 27, 2003 08:37 PM
aznboysrfr
Mar 1, 2003 09:16 PM
kjgracing
23
Dec 20, 2002 11:57 AM
