sidemarker help!!!
Old Nov 17, 2002
Blckcivic01's Avatar
Blckcivic01 is an unknown quantity at this point
sidemarker help!!!
where do i wire the sidemarkers into???
Old Nov 17, 2002
CarbonFly's Avatar
whatever you want........parking lights, turn signal..........however you want them to light up.
Old Nov 17, 2002
well i want to wire them so there isnt any nasty a$$ wires hanigining around in my engine and crap.... and anywhere relativly close to the fenders....like a wire i can splice into or supthing
Old Nov 17, 2002
OmegaBlue2k1's Avatar
OmegaBlue2k1 is an unknown quantity at this point
I just did mine saturday morning. if you run them from inside your fenders, and over your fenderwell, they will end up just under the body frame behind the headlight housings, the wires you need to splice to are right there. Never see the wires in your engine bay.
Old Nov 17, 2002
what wire is it? i want them to turn on when i turn on my signals and when i have my lights on
Old Nov 17, 2002
DrAnsiFL's Avatar
DrAnsiFL is an unknown quantity at this point
I think you have to match the black ground wires and normally you would do green to green for it to flash when turning and not stay on....as for the ghetto look of leaving them on with the parking lights, I dunno. Probably the third colored wire you find in there since I can't think of any other wires needed for the lighting....
Kidding about the ghetto reference, BTW. Good luck. I just did a set of SiR on my 2001 and they look good. Wish someone had a template to make them fit just right though....the shape is different and I had a hell of a time with the dremel tool....looks pretty factory though. [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Brian
BTW: cover any exposed metal from cutting the fender REALLY WELL. I've seen moisture turn to rust real fast depending on where you live.
Old Nov 18, 2002
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
here's some pics from my DIY:
splice the ground to the black wire and the other wire to the red wire (if you want it to stay lit and flash with your signal)
Old Nov 18, 2002
misio4's Avatar
misio4 is an unknown quantity at this point
The only way I was able to hook mine up was either when the blinker is on they will blink or when the parking lights are on they turn on. Is there a way on this 7th gen civic to hook it up so they will stay on and blink also.
Old Nov 18, 2002
Mex's Avatar
Mex
It should stay on and blink when you tap it to the red wire next to the green one [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Misfit2613
Jul 30, 2015 09:49 AM
Mex
54
Mar 2, 2007 08:56 PM
InanimateCarbonRod
Nov 12, 2003 07:24 PM
InanimateCarbonRod
Apr 4, 2003 08:50 PM
ironcow
Jun 15, 2002 09:18 PM
