Installing headers
Old Nov 13, 2002
Konger's Avatar
Konger is an unknown quantity at this point
Installing headers
Can someone help me with a DIY installating headers. It looks like it wouldn't be that hard to install one but I just want to be sure and not make a small mistake that could be big in the long run. Thanks
Old Nov 13, 2002
cambo's Avatar
I wish I was asian
difficulty depends on the car.
on the 2k1+ civcs, some header need to have the motor mount cut. some dont.
Old Nov 13, 2002
nbpEMCivic's Avatar
nbpEMCivic is an unknown quantity at this point
Which brand are you considering?
Old Nov 14, 2002
Konger's Avatar
I have the OBX header for 2K1 ex, 1.7L manual.
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] hd1.jpg (20 Kb)
Old Nov 14, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
Its a pretty east mod, just unbolt the stock manifold and put the new header on. the bolts and nuts attaching to the head are OK except for the one on the far right which you might need some extensions or different sockets to get to. Don't over tighten to nuts when you put them back on! Also the stock setup uses spring bolts to connect to the downpipe, but it looks like your header has some bolts with nuts on it. Hopefully that will work out OK for you. You probably want your car on jackstands so you can get under the engine area to connect it to the downpipe. Other than thats it should be pretty easy. Good luck!
Old Nov 14, 2002
2001civ's Avatar
2001civ is an unknown quantity at this point
IDQcivic said it, you should only have to take 7 bolts off and put 7 back on and one O2 sensor, easy as that.
Old Nov 15, 2002
Hedonism's Avatar
Hedonism is an unknown quantity at this point
my header looks so different then yours, and there is no o2 sensor like they said there will be.
can i just drill a hold weld on a nut then screw on my o2 sensor, will that work?
Old Nov 15, 2002
IDQcivic's Avatar
on the EX the o2 sensor is on the downpipe right below the header and on the cat under the car. The LX has the o2 sensor on the header and another one on the cat right below the header. Make sure you buy the right header for your application or else you might run into a problem, I wouldn't go drilling into soemthing that I just bought!
Old Nov 15, 2002
Hedonism's Avatar
well i live in canada and i bought it in florida, so i dont really care about drilling into it, can it be done?
Old Nov 29, 2002
KeNsHiN's Avatar
LEVA
i need some help too!!
Old Nov 29, 2002
KeNsHiN's Avatar
LEVA
hello
Old Nov 29, 2002
CarbonFly's Avatar
Quote
[hr]Originally posted by: Konger
Can someone help me with a DIY installating headers. It looks like it wouldn't be that hard to install one but I just want to be sure and not make a small mistake that could be big in the long run. Thanks[hr]
A DIY installing headers does not exist for our cars. The only one that I have seen is about installing a header.
Please do all civic owners a favor and say header instead of headers. You only have one cylinder bank, and therefore only one header.
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
17
Jul 23, 2015 11:48 PM
S1N7H3T1C
Jul 21, 2015 05:20 AM
Theshwartz35
Jul 17, 2015 11:13 PM
