Injen cai
Injen cai
Maybe this has been posted before but I could not find it through a search.
Question does anybody out there have a diy on an Injen cai install. I am trying to decide between this and a
AEM. Right now I am leaning towards the AEM due to the bypass option but would like more info on the Injen. Any and all help will be greatly apericated.
Hail to the king baby
INstall is virtually the same.AEM CAI install
Ingen intake is not yet C.A.R.B. legal... AEM is C.A.R.B. Legal
In West Lafayette (Indiana?) CARB doesn't mean shyt. The Injen install is easy. Take off the stock stuff, bolt the top pipe in, take off the bumper (not necessary, but easier to see what you're doing, follow the DIY for cleared lights to get it off), snake the bottom pipe through the splash guard (don't cut it) and the frame. Bolt the bottom pipe to the wire harness tie down point, then attach the 2 pipes. Bolt the filter on the end. Bumper back on, hook the battery up, let it rip. It's a piece of cake, you don't need a bypass. It's enclosed by the bumper... You'd have to drive in water up to the headlight to flood it, and you'd have to be driving through water long enough to fill the bumper cavity. Very unlikely. Plus, you don't have to mess with the bracket on top of the tranny, which saves any trouble arguing with the dealer over the tranny warranty.
Yep West Lafayette IN
thanks for the info.
One question the front bumper doese have to come off??
Only thing with that is it would suck to pull off to clean filter.
But it is true cold air. HUMMMMMMMM!!!!!!!!!!!!!!
Search and Learn
Quote
[hr]Originally posted by: kjgracing
Ingen intake is not yet C.A.R.B. legal... AEM is C.A.R.B. Legal[hr]
Quote
[hr]Originally posted by: WHTRIC
one more question is the injen set up to except the air temp sensor as well as any other conections. I don't want to leave s**t laying loose under the hood.[hr]
Ptuning.com has a pic of the system with the bumper off... I don't. Next time I take off the bumper to clean it, I'll snap a better pic.
The bumper dosn't have to come off for install, but it would make it so much easier. If you don't want to remove the bumper, you can remove the front right wheel, then undo some of the clips and the inner fender and peel it back.
speedracersong
Bolt-on Engine Performance
Jan 25, 2002 11:33 AM
