Blown Motor...Does Honda Replace it??
Old Nov 13, 2002
WhopSi's Avatar
WhopSi is an unknown quantity at this point
I was wondering, If i were to downshift into 2nd lets say, at high speeds, and send the tach needle off the dashboard, would my engine blow? and would honda replace it, or repair it?
Old Nov 13, 2002
CarbonFly's Avatar
Umm........I've reached the rev limiter doing something similar to that and the engine just cuts out so that you don't blow your engine.
I guess it's different if you removed that feature.
Old Nov 13, 2002
Blckcivic01's Avatar
Blckcivic01 is an unknown quantity at this point
i duno but i was downshifting one time going about 60 and was putting it into 3rd and acidently put it into 1st.... and nuthing happened..... lol
Old Nov 13, 2002
PESTLNC's Avatar
PESTLNC is an unknown quantity at this point
Well, even if your engine cuts out and you're in gear, it'll still damage the engine since the wheels will force the engine to turn at a higher than intended speed. Go ahead...try it...5th to 2nd downshift at 80mph on the highway.
Old Nov 13, 2002
PESTLNC's Avatar
Quote
[hr]Originally posted by: Blckcivic01
i duno but i was downshifting one time going about 60 and was putting it into 3rd and acidently put it into 1st.... and nuthing happened..... lol[hr]
How...on...earth...did you do that?!
Old Nov 13, 2002
WhopSi's Avatar
the reason why i ask is because there was a post not too long ago about an RSX that blew its motor doing the same thing. Someone said that the rev limiter works only when pushing the gas, not when downshifting...bope i dunno, just askin
Old Nov 13, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
I guess it depends. Neomagus fawked up his type S and Honda covered it. My cousin's friend misshifted his s2k and Honda covered that as well. On a side note, I also have a friend who misshifted his Celica GT-S and Toyota covered it as well. These 3 cars were 6-speeds BTW. see a trend?
EDIT: The S2000 motor needed new valves,valve springs, and retainers covered it as well. These 3 cars were 6-speeds BTW. see a trend?
Old Nov 13, 2002
AFlyer's Avatar
AFlyer is an unknown quantity at this point
if you miss a shift at or near redline in 3rd, and shift into 2nd instead of 4th, you will blow your engine. the wheels will force the engine to turn at speeds probably in excess of 9000 rpm, and you'll bend valves. bent valves are bad, and that's usually what people are talking about when they're talking about "blown" engines, at least when dealing with missed shifts. i doubt honda would replace that, since it happened due to human error and not manufacturer's defect.
Old Nov 13, 2002
AFlyer's Avatar
Quote
[hr]Originally posted by: WhopSi
Someone said that the rev limiter works only when pushing the gas, not when downshifting[hr]
correct
Old Nov 13, 2002
Ducatti's Avatar
Ducatti is an unknown quantity at this point
Quote
Yeah right! First of all, you would have to be a complete idiot to try to downshift to third and put it in first. On top of that, your gearbox would not have allowed you to stick the gear in first going 60, it blocks the shift gate once you get like past 20. On top of that, if you actually managed to stick it in 1st gear going 60 mph, say goodbye to your engine.
Old Nov 13, 2002
yess24's Avatar
yess24 is an unknown quantity at this point
i heard that about RSX too..
Someone test drove a RSX-S.... shifted it wrong from 5th to 2nd instead of going into 6th...
The whole engine stalled right away.... and burnt smell coming out from the engine... The engine couldn't start after that.. and need to have a tow truck to get it back to the dealer...
Old Nov 13, 2002
ShadyMilkMan's Avatar
ShadyMilkMan is an unknown quantity at this point
Neomagnus blew up his rsx type s mishifting look at his thread under RSX
Old Nov 13, 2002
Crashoveride's Avatar
Crashoveride is an unknown quantity at this point
I have heard the same thing about the RSX, but only in the type S edition. I guess its a quirk that they are aware of and are in the process of correcting, but I guess if you down shift and miss a gear, say 3rd to 1st or something like that, it will blow the engine, or at least do some serious damage. Now as to how true that really is I dont know, because I havent seen or heard of anyone I know doing it.
But hey if anyone wants to take a car out for a test drive and see then be my guest.
Later
Crashoveride
Old Nov 13, 2002
yess24's Avatar
I guess it is more common for pple to shift wrongly in a 6-speed car...
pple are more familiar to shift upto 5th speed .. and the 6th speed location is actually a reverse in a normal 5-speed car and never shift into that position from 5th..
I guess pple who is used to 5-speed tends to shift wrongly from 5th to 2nd or something, afraid that it will get into reverse.
Old Nov 13, 2002
slowasscivic's Avatar
slowasscivic is an unknown quantity at this point
god dayum...learn how to drive people
Old Nov 13, 2002
NeoMagus's Avatar
NeoMagus is an unknown quantity at this point
Dont know about the Civic, but Acura will cover the K20A2 once under goodwill. Unlike the 5 spd trannies, the RSX gearbox dosnt seem to have "lockouts"...where as if you are traveling a certain speed it is harder to put it into a certain gear (ie back to first).
However yea, dont think because theres a rev limiter it will stop...trust me, I got to see my Type S' tach spin past 9k.
Quote
[hr]The whole engine stalled right away.... and burnt smell coming out from the engine... The engine couldn't start after that.. and need to have a tow truck to get it back to the dealer... [hr]
Those guys musta phuccked that up real bad. Once my engine stalled, that was it....however there were no smells from the engine bay. Also no leaks, nothing, the engine would click but not kick over. Don't know how much a D17A2 would cost, but to repair that kinda damage on a K20A2 it is about 9k (service on mine was $8833.43 under warrenty)
Old Nov 14, 2002
htowncivicEX's Avatar
htowncivicEX is an unknown quantity at this point
Honda will cover a blown motor due to a misshift the first time you do it. They call it the "goodwill" policy. Technicians are always bitching about it, because warranty work pays them about 1/2 than if a customer paid it out of their own pocket.
Old Nov 14, 2002
Les's Avatar
Les
Les is an unknown quantity at this point
I bought my 01 used and had the engine blow 12 hrs later. I didn't buy it from a honda dealer and I think the problem was that they did an oil change and forgot to put oil back in. I got a bunch of crap from the dealer where I bought it. They tried to do everything possible from when it happened to keep from taking the blame, ended up getting a lawyer that day. When it got to honda they never gave me any problems. Replaced the engine under warranty (It did take around a month and half because it was back ordered), but it's not their fault. It got to the point where the manager at the place I bought it was avoiding us, so we tracked down where they sent it and from that point on the service manager at honda was giving us calls weekly to update on the status. I've had no problems since then and I'm very pleased with honda.
Old Nov 14, 2002
S2000man01's Avatar
O RLY
Since the question about whether honda will cover it has been answered, I will address the rev limiter talk...
All a rev limiter does is cut the fuel to the engine, thus not allowing you to rev any higher as you accelerate. However, if you mis a shift say from 3rd, and you accidentally put it into 2nd and not 4th, then the engine WILL REV well beyond your redline since the wheels force it to once you disengage the clutch. This could send your RPM's well beyond 10,000rpm or in my case, even 12,000rpm. And the above stated damage can occur. (valvetrain stuff)
I have done this twice in my S2000.... gone into 2nd instead of 3rd at like 80 or 90mph.... luckily my car has taken it, and nothing was damaged. It's an easy thing to do on an S2k since it's a mere 20mm throw from gear to gear. (shortest throw on any production vehicle)
Old Nov 14, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
Quote
Ummmm.... your profile says you have an automatic. So WTF were you doing downshifting in the first place [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Nov 14, 2002
n00dleboy's Avatar
n00dleboy is an unknown quantity at this point
Just hit the clutch if you misshift, you should be able to butt-feel it if you p***k up.
Old Nov 14, 2002
JohnnyLee's Avatar
7thgen guh chee
Good lord I better be careful not to mis shift and blow out the engine
Old Nov 14, 2002
WhopSi's Avatar
This is mainly directed to Les. You said you blew your engine, and honda replaced it. Did they repair it, or actually drop in a new one??
just wanna make that clear
Old Nov 14, 2002
Les's Avatar
Les
I got a brand new engine[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Nov 18, 2002
DaCurryman's Avatar
DaCurryman is an unknown quantity at this point
damn, with all the mistakes/problems you people have...it kinda makes me glad to have an Automatic.
Old Nov 18, 2002
RiceBuRNeR's Avatar
Turbo Member
I missed a shift and blew my engine w/ only 14,000 miles on it and honda rebuilt mine on warenty.
Fastfebur
Apr 22, 2015 01:37 PM
jessicakaybby
Apr 20, 2015 12:11 PM
smmahan
Apr 15, 2015 08:17 PM
thesushiboy
Apr 12, 2015 02:54 AM
Bartkat
20
Feb 19, 2002 01:29 PM
