Need help finding a wire
Old Nov 18, 2002
RiceBuRNeR's Avatar
Turbo Member
Does anyone know what wire on pre-cat o2 sensor is the signal wire? Im hooking up a air/fuel meter so that i can fine tune my V-AFC to get more power then I can share the program w/ everyone.
Old Nov 18, 2002
CrankinCivic's Avatar
CrankinCivic is an unknown quantity at this point
i have mine hooked up to right where the header meets the rest of the enine and i beleive it is a black wire
Old Nov 18, 2002
RiceBuRNeR's Avatar
Turbo Member
hmm, i thought black was the ground for the heater element?
Old Nov 18, 2002
Desi's Avatar
Desi is an unknown quantity at this point
don't you need to tap the signal wire on o2 sensor on the intake b/c its before the engine. the fuel needs to be adjusted according to air going into the engine not the air coming out (from the header).
Old Nov 18, 2002
RiceBuRNeR's Avatar
Turbo Member
This isnt for my V-AFC this is for my air/fuel gauge...you dont even use the sensor on the intake for the v-afc anyways, I just need know wich wire on the o2 sensor wire is the signal wire.
Old Nov 19, 2002
APS's Avatar
APS
APS is an unknown quantity at this point
Just hooked mine up the other day....it's the white one.
Old Nov 19, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
Quote
[hr]Originally posted by: Desi
don't you need to tap the signal wire on o2 sensor on the intake b/c its before the engine. the fuel needs to be adjusted according to air going into the engine not the air coming out (from the header).[hr]
Learn what you are talking about before misinforming people, I could just see someone hooking up a a/f gauge on their intake and screwing things up bad! You have no clue what you are talking about, o2 sensors are on the EXHAUST. The sensor on the intake you are refeering to is the IAT and reads temperature! For being a super member you must post a lot of crap! ALso the fuel is adjusted by the emissions, depending on how much emissions are in the exhaust it adjust the fuel map, that's why the o2 sensors are in the exhaust. The intake is for air coming into the car!
Old Nov 19, 2002
wh3nw0rdsesc4pe's Avatar
wh3nw0rdsesc4pe is an unknown quantity at this point
It's the white one, he is correct....
Old Nov 19, 2002
IDQcivic's Avatar
yeah the 1st o2 sensor its the white one, the 2nd o2 sensor its the black one.. I was talking to Desi as being wrong at saying the o2 sensor is on the intake, WTF....
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
MamaBear2015
May 3, 2015 02:17 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
clockwerx
Dec 13, 2001 12:39 PM
blackbullet
Dec 1, 2001 03:44 PM
