o2 simulator install?
Old Nov 5, 2002
PhilyStyle's Avatar
PhilyStyle is an unknown quantity at this point
does the o2 simulator connect directly to the ecu or the second o2 sensor directly?
Old Nov 5, 2002
PhilyStyle's Avatar
if anyone has done this install please help?
i need some the details, the instructions that came with it don't have the 2k1 civic listed and all the civics have different wire color charts. [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Nov 5, 2002
SLeePeR012's Avatar
SLeePeR012 is an unknown quantity at this point
PM IDQcivic
Old Nov 5, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
I posted the DIY about 5 times if you search the forums, it was just talked about like a week ago and probably every week before that too...
Its just a 5 wire hook up
red postive on battery
black negative on battery
RPM wire - blue wire to left of battery under black boot
TPS wire - red/black wire in middle wire in group of 3 wires by throttle body
o2 sim wire - cut black wire off 2nd o2 sensor, tape end going to sensor, run the sim back to the harness that plugs in the car. leave other 3 wires alone and wrap the sensor in foil. tie under car somewhere
thats it and good luck!
Old Nov 5, 2002
CivicRacer5's Avatar
CivicRacer5 is an unknown quantity at this point
Would the Check engine light still come on if something other than the O2 sensor was messed up or would this simulator completely disable the check engine light??
Old Nov 5, 2002
JDM1982's Avatar
JDM1982 is an unknown quantity at this point
Yes, because you are telling the ecu that the cars O2 sensor is still doing the job it supposed to. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Nov 5, 2002
civicvtec1ps's Avatar
Search and Learn
Quote
[hr]Originally posted by: IDQcivic
thats it and good luck![hr]
just make quick DIY if you have time you know. cause i see o2 installation questions every week!!
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
