click me please!!!!!
Old Nov 19, 2002
Gryphin's Avatar
00 Hatchback Owner
Would putting a bigger/better cam in are civics along with injectors give the engine a big boost? or with are engines, would that not help? because ive been talking with a few friends who race trucks and stuff, they said if you want some more horsepower upgrade my cams and injectors...... so please help
Old Nov 19, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
Well we only have 1 cam because we are SOHC, and there are none out yet [IMG]i/expressions/face-icon-small-sad.gif[/IMG] but you can have your stock cam reground to help boost performance. As for injectors, I think our stock injectors are fine, unless you are running some sort or forced induction then you could upgrade them.
Old Nov 19, 2002
fuledya's Avatar
Super Member
fuledya is an unknown quantity at this point
ISN'T THE EX A DOHC?
Old Nov 19, 2002
BIGGODLO's Avatar
BIGGODLO is an unknown quantity at this point
No it isn't. It is SOHC VTEC. The SI was DOHC.
Old Nov 19, 2002
2001civ's Avatar
2001civ is an unknown quantity at this point
The bigger injectors are for if you need more fuel, but like IDQcivic said, you don't need more fuel unless you are running something like forced induction, and a new cam would be good if you can find one but best used with a dyno so you can tune it just right with cam gear.
Old Nov 19, 2002
BlueRevs's Avatar
BlueRevs is an unknown quantity at this point
Quote
[hr]Originally posted by: fuledya
ISN'T THE EX A DOHC?[hr]
Im not trying to flame, but um, Whoa. Damn i wish it was. then trying to pull power out of bolt ons wouldbe more productive, and worthwhile.
Old Nov 19, 2002
doubledeuce2k2's Avatar
why is it i can go to a neon web site and see them saying a sohc is a better street car than the dohc?
Old Nov 19, 2002
correct that slightly...
2.5.1 Q: Which engine is better?
A: As with all things Neon, opinions vary widely. However, many feel that the SOHC is better for street use because its torque peak is lower in the rpm range, allowing the engine more time in its power band under normal driving conditions. The SOHC is also a better choice with the automatic transmission. The DOHC does have more power in the top end, above 6000 rpm, which makes it the main choice for racers and autocrossers. Torque is also a bit higher throughout the power band.
Under competition use, though, the DOHC does require more careful maintenance to avoid problems with its more complicated valvetrain. The DOHC is somewhat prone to rocker failure, and does not quite have the same reputation for bulletproof racing reliability that the SOHC enjoys.
^originally posted on Neons.org
Old Nov 19, 2002
2001civ's Avatar
Totally a matter of taste in what you like in your car. somepeople love nitrous, some hate it. AND A NEON!!!!! : tdown: but your at a honda site so thats cool
carid
Sep 28, 2015 10:13 AM
Skunkone
Sep 24, 2015 04:38 PM
charmon4815
General
Sep 22, 2015 08:00 AM
Juanb24
Sep 15, 2015 12:39 AM
Josh 1973
Sep 7, 2015 10:10 AM
