Another Indiglo Guages Question
so i just connected my guages everything's installed correctly (i think) i turn on my headlights and the guages aren't bright at all. yes i have the dimmer all the way up. anybody have any ideas?? is it something i did, or do you think they are just some dim a$$ guages?
thank you all for the help
try turning the dimmer all the way down, if it doesnt make a difference then you hooked up the dimmer (potentiometer) wrong...if it does make a difference i would check your connections, make sure there arent any shorts and I'd solder your connections if possible.
You also want to make sure the car is turned on and running. The regular indiglos I got from autodynamic.com turn off and flicker without constant power. Sometimes when I have the stereo on they start messing up. It's also like they need alternator power or something.[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
make sure you get power from the red with black wire. I had my old gauges hooked up to the solid red wire and I had to turn the dimmer all the way down, and eventually the indiglos burnt out. Now that i hooked it up to the red wire with black stripe they work perfectly, and my new gauges have their own dimmer **** which is sweet!
junkyardguy
Sep 2, 2015 06:07 PM
martinsmartin
Aug 15, 2015 07:34 PM
brennov8
Jul 13, 2015 12:57 PM
