HONDA TECH please help w/tach
Old Nov 20, 2002
chefjnr's Avatar
chefjnr is an unknown quantity at this point
MSD techs are of no help to me with this one, maybe one of you guys tried:
Msd P/N 8956 RPM window activated switch
http://store.summitracing.com/partdetail.asp?part=9019
Anyone hook one of these up to a 01 civic and how did you do it? I guess there is problems with our DIS system and there being no tach out line
Old Nov 20, 2002
AlpineCivic's Avatar
here's some Tach info provided from WireMagic.com
TACH
The TACH WIRE is generally the negative side of the vehicle’s coil(s) or Distributor. This is required for a Remote Start installation when the manufacturer’s unit specifies a connection to the vehicle’s tach wire. It is an AC signal and generally ranges between 2-13 volts during run. The higher the engine speed, the higher the voltage will read. Any short to ground or 12-Volts on this wire will generally cause the vehicle to stop running or, may also cause the vehicle to exert erratic behavior such as " bucking" and intermittent stalling during normal operation.
2001 Honda Civic Tach:
Blue At tach test connector * This plug is located on the passenger side of the engine compartment between the battery and the headlight. Set your remote starter for 4 cylinders
Old Nov 20, 2002
This info is for a remote start I dont know if it will help you
Old Nov 20, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
yeah the RPM wire on our cars is the blue wire to the left of the battery with a black rubber boot thing on it, I've used that wire for my alarm with remote start, and also for my o2 simulator. I bet thats what you need!
Old Nov 20, 2002
Atlantis's Avatar
Atlantis is an unknown quantity at this point
If you don't want to run a wire through the firewall you can get the same blue wire running into the instrument cluster. Its connector A (the green one) Pin 13.
The wire is there on all models including the DX, even if there is no tach gauge.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
jessicakaybby
Apr 20, 2015 12:11 PM
Bartkat
20
Feb 19, 2002 01:29 PM
deception420
Dec 6, 2001 02:31 PM
artychris
Nov 11, 2001 10:23 PM
