air fuel
air fuel
i bought an autometer sport comp air fuel guage and i can figure out what color wire i hook it up to for the 02 sensor i have everything else hooked up. dores anyone out there know which wire for the 05 ex is the one
Broken Arm, How Am I Suppost To Shift
Autometer Ultra Light A/F.
Red= Power
Black= Ground
Purple= o2 Sensor.
Mine works fine. and gives me Accurate Readings.
Red= Power
Black= Ground
Purple= o2 Sensor.
Red= Power
Black= Ground
Purple= o2 Sensor.
Red= Power
Black= Ground
Purple= o2 Sensor.
You must have a "full throttle" modified autometer gauge. In which case it is still only accurate at full throttle. If its stock, then none of the readings are correct. Its a flashy light show and thats about it.
Originally Posted by gearbox
those gauges don't work and mess up the o2 sensor. Only get a wideband. The one you have won't be accurate anyway.
well if you want to run a cheap gauge, i would suggest sending it in and they can adjust the voltage to accurately read full throttle a/f. Even then, I would use a SEPARATE 02 sensor that you weld in someplace. Ofcourse the ideal way would be a wideband sensor, but that's gonna cost hundreds of $$.
i have an etra hole on my header so i instaled it there and got nothing. right know i have it installed on the stock one bellow the header and all i get is a light show the darn thing keeps going from lean to rich non stop onless i step on it then it stays on rich
tock172
Jul 21, 2015 06:25 PM
juror
May 26, 2015 06:35 PM
