A/C Expansion Valve
Old May 19, 2005
RallyeRed04's Avatar
RallyeRed04 is an unknown quantity at this point
A/C Expansion Valve
Hey, I'm pretty new to posting threads on here. I took my car to Honda today to get state inspection and all that stuff, and I also complained about my a/c blowing out warm air. They called me back and said that they refilled my freon and checked for leaks. Well they found out that the expansion valve is stuck open. They are ordering me a new expansion valve and it is covered under warranty. I was just wondering if anyone else had this problem? ... I was just suprised this happened so soon because my car is not even a year old.
Old May 19, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
what year is the car?
Old May 19, 2005
Blahman240's Avatar
oh... 04? Well... no, never had that problem.
Old May 19, 2005
yeah it's a 2004 EX 5spd
Old May 19, 2005
streetglower's Avatar
it isnt really a problem, it happens. As long as its under warranty, it is ok.
Old May 19, 2005
tacheon's Avatar
tacheon is on a distinguished road
If your car is 2004, then it must have been charged with 134a not freon. Freon is also known as R12. They are not the same and the lubricants used in each system are generally not compatible with eachother.
Old May 19, 2005
most of the time if they had to refill it and check for a leak, then there was a leak. If it was just your expansion valve, then there shouldnt have been a need to refill it with refrigerant.
just cause it is a new car, doesnt mean it wont fail. I have seen cars with 6 miles at my work already have check engine lights on, SRS lights, a brand new SL55 with 128 miles came in with a burnt up transmission 2 weeks ago. **** happens.
Old May 19, 2005
Sorry for the mix up... it is r134a. The reason why I called it freon is because it says freon134 right on my receipt. They recharged the system because when they checked it, it only had .1 LB of r134a. So they charged the system and checked for leaks and found that the expansion valve is stuck open.
I realize **** happens, and the world isn't perfect. I just wanted to see if anyone else experienced this problem.
Old May 21, 2005
T72DohcVtec's Avatar
T72DohcVtec is an unknown quantity at this point
Question my ac drier sensor
Hey i need someone that understand and know what am talking about please, my problem is in my 01 civic coupe all started about a few days ago when my wife turn off the ac on the car before she turn off the car and she felt a quick shaking in the engine. she came and told me about IT then we didn't had no ac after that so i check on my fuses and i found out the ac condenser fan fuses was blown so i replace it and it keeps blowing fuses i check and i came with the conclusion that everytime i plug the ac drier switch it blows the fuse AM GUESSING IS THE DRIER SWITCH. PLEASE IF ANYONE KNOW ABOUT OR XPERIENCE THE SAME SITUATION GIVE ME A HINT.BEFORE I GO AND SPENT $49 DOLLARS WHICH THATS THE VALUE THANKS. I LIVE IN MIAMI AND IS VERY HOT HERE I NEEED MY AC BACK.
Old May 22, 2005
You have a short somehwere, and I highly doubt it is the switch causing that. If the fuse for the condensor fan keeps blowing, you need to check that specific circuit. You probably have some wires shorting to other wires or shorting to ground.
mjdiaz89
Jun 21, 2016 09:26 PM
mcollins
Electrical
Jul 27, 2015 10:59 PM
cukaracha
30
Jul 26, 2015 12:01 PM
cukaracha
Jul 23, 2015 08:50 AM
Jul 14, 2015 03:39 PM
