spc camber kits
Old May 21, 2005
BERGER's Avatar
BERGER will become famous soon enoughBERGER will become famous soon enough
spc camber kits
i need to get a camber kit because i've gad to replace my tires, but i thought u only need a camber kit if u lower your car... my car is stock height and i don't know why the tires are worn down to the cords already... anyways i need some help quick... does anyone know if this is a good kit?
Brandon
Old May 21, 2005
streetglower's Avatar
Well have you had your alignment checked, or did you just keep driving on your tires untill the cords started showing. Just cause the cords start showing doesnt mean you need an alignment. Now if it is only on one side of the tire and the other side has alot of tread, then it needs an alignment. And no even if a car isnt lowered, it might not be able to get back within specs do to parts wearing out.
Old May 21, 2005
BERGER's Avatar
all 4 tires were like this on the one side with the cords showing through and when i'm driving i can take my hands off the wheel and it doesn't go to either side..
Old May 21, 2005
BERGER's Avatar
all 4 tires were like this on the one side with the cords showing through and when i'm driving i can take my hands off the wheel and it doesn't go to either side.. and this was only with my aftermarket rims.. my stock rims and tires are fine.
Old May 21, 2005
LiKEaFeRiO's Avatar
Overall diameter of your aftermarket wheels/tires may not be the same as stock diameter.
I had 205/40s on 17 inch rims on stock suspension.
The alignment was to specs with the stock diameter so over time I had camber wear.
Go get an alignment and it should fix the problem unless your aftermarket tire size is way too off.
Old May 21, 2005
my1vtec's Avatar
my1vtec is an unknown quantity at this point
yes alignment
Old May 21, 2005
civic01vtec's Avatar
do u check your air pressure regulary ?
Also, get a alignment
Old May 21, 2005
BERGER's Avatar
yeah i made sure i had the right tire pressure in them and i have the same tires 205/40/17 should i also get the spc camber kit just to make sure it wont happen again?
Old May 21, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Irrelevant, Tire diameter doesn't effect suspension geometry.
Get your alignment checked. It doesn't take much to eat tires quickly.
I take it you ripped up the inside edges, which is usually a sign of toe in. How many miles are we talking here?
Old May 21, 2005
LiKEaFeRiO's Avatar
This was when I had 17's not long after I got the car so it was whatever specs the factory put it.
If I remember correctly it was around 10k?
So if my new wheel/tire size is...say 5% off using the tire calc, the tires would still be flat and level to the ground without a need for an alignment?
If it is, then I drew a bad picture in my head
Old May 21, 2005
Jap-Euro Fusion
The car just sits lower by whatever amount the tire is shorter. You didn't change anything in the suspension. If no geometry changes, your alignment doesn't change either.
I do my alignment with different wheels on the car every time I do it, it doesn't matter.
Old May 21, 2005
BERGER's Avatar
the edges on mine were ripped up but on all four of them..
Old May 22, 2005
Mr.Modify's Avatar
i've got that kit man. Riding for a year now on it
Old May 22, 2005
goodtimes's Avatar
i have a ?.when i had it my alignment done i had 215/40/17 on my car then i changed to 195/60/15 my ? is should i get an alignment or should the tires be ok....
let me know thanks
Matt C.
Old May 22, 2005
goodtimes's Avatar
bump for ? anyone?
thanks
Old May 22, 2005
Jap-Euro Fusion
let me know thanks
Matt C.
Did you read a word of what I just said?
Old May 22, 2005
burke420's Avatar
The World Is Yours!
the SPCs...are greatr camber kits... but have a wheel shop to inspect your tires and get a proffessionals, opinion on this matter, it may jus be a alignment or could be something wrong with toe or something, but my SPC is great andd nicht problems....
Old May 23, 2005
goodtimes's Avatar
dam dude a yes or no would of been good....
so i dont need an alingment b/c the tire size has nothin to do with camber/toe ect..... it just lowers the car more...
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
