Removed seats, now SRS light is on!
I removed both front seats this weekend so that I could vacuum and wash the carpeting. No problems unbolting seats and removing the two electrical connections underneath.
So I vacuum, use a Bissel steam cleaner to clean up the carpeting and seats, let it dry out overnight and put the seats back in. Reconnect everything and all seems well. That is until I start the car and the SRS light refuses to go off.
I rechecked the connections and everything seems tight. I then removed the negative connection from the battery for about 10 minutes and still the light is on. Help!
New Mod on the Block
you need to reset your srs. there's a diy for it. just SEARCH for it. this topic has been covered at least a hundred times. Go Here
you are going to have to reset your SRS light. There is a DIY for it and can be found here. Goodluck and welcome to the site. Most of the stuff that will come up in your course of modding have readily available information already and I would encourage you to search. Here is the DIY for the SRS light:
http://www.7thgencivic.com/forums/sh...d.php?t=155251
goodluck
goodluck
Originally Posted by gearbox
interesting. I installed new seats in mine and nothing happened when I unplugged connectors.
hey, i had srs light too when i put rsx-s seats and i tried that ressetting think and it blinks twice and still light stays on. its wierd, i hope the srs wiring aint cut or anything fawk!!!! its sooooooo annoying, especially at night.
AKA Mr. 60ft. Not to be confused with Civic_Redline
SRS light member here too. Always taking out the passenger seat so mine just stays on all the time.
Since we're on the topic anybody know if the airbags will still deploy with the light on?
Anyways I'm going to take it to the dealer and see if they'll reset it. I bought two cars in two weeks from them, so they should cut me a few breaks!
Since we're on the topic anybody know if the airbags will still deploy with the light on?Registered!!
I'm not sure if you did this or not, but you have to disconnect the battery BEFORE you unplug the yellow connectors. From your post, it sounds like you replugged everyhting, and then you disconnected the battery.
I just installed some seats, and this really works.
Lesson learned.
no, battery stayed in. I just didn't start the car...why would you anyway without seats?
I was extremely hungry so after I installed my driver's seat, i went to McDonalds.....lol. Hey when ur hungry, thats all you care for....lol
But its fixed now so its all good Thread
Blazz
May 25, 2015 10:56 PM
jimmyfloyd
May 20, 2015 07:06 PM
SimDogg
Nov 27, 2001 04:20 PM
