New 05 EX starts hard
Old May 19, 2005
honda860's Avatar
honda860 has a little shameless behaviour in the past
THe past couple of mourings Iits been I would say around 55 or so degrees and my new EX seems to take a second to pop off when im trying to start it. I dont think its that cold so it should start up normal. Anyone else have this problem? My older 2000 ex does the same thing but it use to do it when the gas was low. in my 05 even when i have like 3 quarters of a tank it does that i would say probably 45% of the time. Let me know what you think
Old May 19, 2005
Civic_Moogles's Avatar
Civic_Moogles is an unknown quantity at this point
My 02 EX kinda does the same thing every so often. Im in tx so the weather here really doesnt get that low often. I took it to honda to have an inspection done right before i hit 30,000 and told them about the prob. They couldnt find anything wrong with it. Im pretty sure its because of low gas....im not sure though.
Old May 19, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
WI gets pretty warm ok, not really but I dont have any problems starting my car in the winter and it gets pretty cold. 04 ex 18k
Old May 19, 2005
03civda's Avatar
03civda is an unknown quantity at this point
Low gas. When hondas get even remotely close to low gas and it settles for a while, it will start like that. Happens on my 03 EX and on my mom's 99 LX.
Old May 19, 2005
honda860's Avatar
See the thing is it happens even when i have 3 quarters of a tank. I mean it doesnt happen alot but i guess it could be a gas problem i do remember though having a little less then 3 quarters of a tank parked it after i got home from work at 5 one night got in at 8:30 the next mouring and it did it
Old May 19, 2005
Octane Joe's Avatar
are you parking on a slanted surface (such as a driveway) becasue my car does the same thing if I park to high on my driveway, we have a small slope, but if I get too close to the house, my rear tires hit a little bump, and if I go farther than that, my car has a hard start in the morning, the fuel gauge reads normaly, but it starts like I have low fuel(BTW it did it this morning and I have a full tank)
Old May 19, 2005
honda860's Avatar
actually i park in back of my apartment building which is a flat surface. but i see the point your trying to make. the parking lot itself could have a slight slant but it defiantly is not a noticable one
Old May 19, 2005
Boggie1688's Avatar
Diamond Member
Boggie1688 is an unknown quantity at this point
Hey have I have the same problem. I have an 05 ex only 2 months old. When I park the car say outside when I got to my friends house then party all nite and wake up and leave in the morning, that car really cranks a lot before it fires up. I noticed that and told the dealership...they blamed it on my intake. I dunno what really wrong with it, but once the car warms up and u turn it off and try again the problem is gone. Also my car is garaged when I'm at home...sooo normally when I get up its fine. Only when its parked overnite in the cold.
Old May 19, 2005
honda860's Avatar
hmmm well im glad to see there are other people with the issue. it happened in my 2000 si as well. but i dont have any idea what it is. it could be gas like people state or sumthing else. not your intake though cus i havent modded mine at all yet i have all the parts but none are on so mine is completely stock and i have that problem. what the hell right haha
Old May 19, 2005
Al Gore FTW's Avatar
jdmtytedoridori
when you guys start up your cars, turn it to the on position for a few seconds, so the fuel system can pressurize (or something like that). then start the car. mine used to have that problem, but now that i do that EVERY time, it hasnt happened in a while.
Old May 19, 2005
honda860's Avatar
good point thanks for the info man. Im glad to have a forum where i can get all the answers and learn so much
Old May 19, 2005
Boggie1688's Avatar
Diamond Member
Done it....I remember I asked about my problem...soo someone told me that tip. Same problem...
Old May 19, 2005
honda860's Avatar
cool ok ill have to do that from now on if i let my car sit for a bit.
Old May 19, 2005
Octane Joe's Avatar
if that fixes the problem, it is your fuel pump need priming... my friend had that problem w/ his firebird... but the only way he fixed it was to get a new fuel pump... but maby I would suggest changing your fuelfilter first if you are going to go that route, just to be on the safe side... fuel filter is cheaper and my just be what is slowing you down... just a thought...
Old May 19, 2005
honda860's Avatar
yeah ok thats for the tip. its jsut the car is not even 2 months old it only has 800 miles onit so its like what the hell, already!?! you know
Old May 19, 2005
Octane Joe's Avatar
true... ok, maby im wrong... lol wouldnt be the first time
Old May 19, 2005
honda860's Avatar
you know more then i do. Thats why im here haha
Old May 19, 2005
Octane Joe's Avatar
^ I like your additute, rep+ and 1000 points comming your way!
Old May 19, 2005
Kyle23's Avatar
I forgot how to start my car since I got a remote start
Old May 19, 2005
Octane Joe's Avatar
lmao
Old May 19, 2005
savedadogs's Avatar
savedadogs is an unknown quantity at this point
I usually wait until the flashing green key sign disappears before starting the engine.
Old May 20, 2005
honda860's Avatar
hey thanx silvercivic. yeha i plan on learnin as much as i can and doing the best for my car from what i learn on here. Im a computer geek myself i make like 40 G's a year start in my career as a programmer so if anyone needs help with that kind of stuff let me know as far as car stuff ill look to you guys on here
Old May 20, 2005
cg95660's Avatar
Wanna see a donkey show?
cg95660 is an unknown quantity at this point
I usually leave my key in the one posittion for a second before starting. I feel that this lets the cars fuel pressure build up before turning over. I will only do this if it has sat for a long period of time like over night.
CarStuff
Dec 6, 2020 12:52 PM
jbradley4809
Apr 7, 2017 04:23 AM
MamaBear2015
May 3, 2015 02:17 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
black2k1vtec
Dec 6, 2001 09:49 PM
