A Few Issues, may have heard of some already
Old Jun 3, 2005
Whelan's Avatar
Whelan is an unknown quantity at this point
I did search a few of these but here they are so far. I am looking for either a yes thats what you should do or any advice from people who have had these problems. Thanks.
1) They say they fixed my seat but after a few months it is back to that rocking issue.
2) The heat only works when the car is moving, when at a light it blows cold air. I also noticed last night that my car was jumping from 3/4 back to low on the temp then back up to 3/4. I used to never see it go over 1/2 so I am thinking thermostat. I have bumper to bumper wonder if this covers it, only 50k on the car.
3) Weird rattle from rear passenger seat, I think somethin is loose back there not sure what.
4) Headlights blowing. It only happens when I turn the lights on, once in a while about every 3 months when I turn the switch the lights go on and blow out real quick (flashout). I asked the dealership about it and they said there was no recall but I have the NHSTA paper printed out that says all about the issue so I am goin back to the dealership to get it fixed.
5) Clutch pedal is now making a creek sound like a door opening when presseed and depressed at times. I am thinking just some grease would help.
6) When shifting to reverse it will occasionally either pop out of gear or just whir as if I was in neutral. I cannot figure out why I put it in gear all the way, and for now I have to shift to first then back to reverse to get it to work. Even then it doesnt always cooperate, another dealer issue I will bring up.
7) The car is at 50k and other than typical oil change, and getting my tranny flushed, what else can be recommended to keep everything at par.
Old Jun 3, 2005
Importracer's Avatar
Importracer will become famous soon enoughImportracer will become famous soon enough
good luck with getting any of these fixed, When I took my car in for its 50,000 mile checkup, i told them about the same things pretty much and all they were able to fix was the clutch squeak, which is easily remided by lubing the linkage underneeth the hood. The squeak will never go away, honda sucks at making manuel transmissions. Everyone thats ever owned a honda with a 5/6 speed knows that the clutch eventually starts squeaking. The tranny fluid flush might help with the car popping out of reverse, but i think its more a syncro issue. good luck man
Old Jun 4, 2005
Whelan's Avatar
anyone else, just one reply in a day?
Old Jun 4, 2005
flotsamm's Avatar
Check out the TSB section here under Downloads, it covers some of the items you mention.
Old Jun 4, 2005
streetglower's Avatar
#1. the rocking seat issue has to do with worn out bushings. take it back and have them put in new ones.
#2. you said you had no coolant in the other thread and it keeps leaking out somewhere. Do a pressure test on the system, otherwise add it full of coolant and let the car run and stand there and see if any leaks out.
#3. If something is loose, take the seat out and put it back together making sure to tighten anything.
#4. there is a TSB out for the headlights. And the dealership knows about it. If they say otherwise, show them the TSB.
#5. use some white lithium grease on the bushing on the clutch pedal. Should take the noise away.
#6. cant help you with that one, take it to the dealer.
#7. change your spark plugs, air filter, rotate tires, balance them, change AC filters, check brakes. And grease up everything. Maybe change brake fluid and coolant.
Old Jun 5, 2005
Whelan's Avatar
Brake fluid and coolant is all good now, changed and all. Brakes are new, tires are new and balanced/rotated.
Still have to change the plugs, change A/C filters and get the tranny flushed. Thanks man.
snekyninja
General 8th & 9th Gen
Apr 21, 2020 10:35 AM
Dave88LX
Jun 2, 2016 03:43 PM
Wild Cranker
427
Jan 28, 2016 06:49 PM
chuffsy
May 15, 2015 12:50 PM
Jessica Leung
May 5, 2015 05:12 PM
